1.0.7 is the forth firmware update for the Onefinity CNC Controller.
This is a MAJOR release. A lot has been fixed, updated, and improved. We’re investing more effort into improving the software and want to thank the team who’s been working hard doing so.
How To Install:
Updating via USB
You’ll do an update via USB using the following steps:
Copy the blue .bz2 file below onto a usb stick (it must be formatted as fat 32 or ntsf). Click the flyout menu (three bars on top left), general, under firmware click ‘UPLOAD’. Select the 1.0.6 file. Depending on your shipping date, the password to update will either be buildbotics or onefinity
Updating via the Internet:
If you already have 1.0.6 and below and are connected to the internet and have auto updates on, a pop up will inform you that there is an update and the machine will update automatically via the internet.
If you already have 1.0.6 and below and are connected to the internet and do NOT have auto updates enabled, go to Click the flyout menu (three bars on top left), general, and under firmware click upgrade.
onefinity-1.0.7.tar.bz2 (2.1 MB)
Change Log:
- Cleaned up UI layout a bit on the main screen
- Enabled auto expansion of partition and file system to fill SD card on first boot
- Added probe continuity test before probing (pop-up dialog)
- Added a popup after probing, reminding the user to put away the probe
- Lowered default probe seek speed
- Fixed file drop-down menu showing old files
- Added file system watcher for uploaded files
- Improved support for large gcode files, improves performance on Raspi
- Fixed a bug where the UI could become unresponsive at boot, or when uploading the first gcode file
- Changed default max-deviation to 0.001 to reduce issues with chattering while cutting arcs and circles
- Hides ratpoison (window manager) message during boot up
- Disabled G61, G61.1, G64 gcodes until the root cause of circle chatter is identified and fixed
- Increased icon size on the main GUI
- Improved version comparison logic for handling public beta releases in the future
- Changed default max-jerk to 1000 for X/Y axes
- Changed default idle current to 1A
- Force-set some critical configuration values to help with reliability
- Metric units only for junction-accel and max-deviation
- Rewrote the homing procedure to be more consistent
- Small improvements to the stall homing procedure
- Fixed error messages in the console (webgl)
- Fixed styling bug with error dialog
- Added a setting to allow enable/disable of probing safety prompts
