Box joints/dovetail substitute?
Is there any woodworking joint that will work to join two boards at a 90 degree angle that doesn’t require vertical mounting? Preferably something that looks cool?
I.e. a substitute for a fingerjoin or dovetail?
I’d like to pop out some bookcases. I don’t even know if it’s possible but it seems like it should be.
I’ll probably get corrected on one or more of these but
tongue and groove
mitered 45’s
lap
dato/rabbet
scarf
cove and pin
I’ve done half-blind box joints laid flat. There are some visible filet holes but not from the blind front face and I personally liked the look from the side:
4946e6b82c7284326e29beaec9a708a259f91e26
003e0904f531252ed93a7edcfc3c147f4557b22b
b4971061dddb3489db1eed13fc0ad689fb981aea
that’s cool. How did you lay them out?
I’ve done something similar with a box joint where everything is machined flat. There are dogbones in the corners to allow the pieces to fit together.
I just did it manually in vcarve as a test of a home-built CNC. Created the edge profiles and then just copied them to all the relevant sides. Looks like jointcam or a similar program might do this for you if you’re going to be doing it regularly, but I was just trying it out and it wasn’t that hard to lay it out manually for 3 different-sized boxes.
