Common Bolt Types on the Onefinity
X Rail
8 Bolts holding down the X Rail to Y gantry blocks : m6 x 22mm long
Y Rail to QCW
16 bolts holding the Y feet to the QCW blocks: m6 x 22mm long
Stiffy
2 M5-0.8 x 16mm (ends)
2 M6-1.0 x 14mm (gantry)
2 M6x6 7380-10.9 (short)
Z Slider Z-16
4 bolts holding the z slider to X gantry: m5 low head x 12mm long
2 bolts squeezing the mount together : M5 x 30mm
Z Slider Z-20
Set screws for holding bearing in place:
m5 x .8mm. 4mm long. Flat tip set screw. McMaster-Carr 92605a227
Touch Screen Mount
4 long bolts m5x70 and 4 m5 nylon locking nuts.
Dust Boot:
Button Head screw that holds the router shield: 6/32 1/4 inch (mcmaster-carr link)
Oil Port
M6 socket head by 6mm long. McMaster-Carr
Wiper grub set screw on ends of feet
m4 x4mm long set screw.
Wiper grub set screw on X35 ball screw
M3 x 4mm cone tip
Plate on top of x gantry to hold the z motor and router cable
M6 x 1.0 × 14mm
Suck It Dust Boot:
Dust boot shields (black): 6-32 x ¼
QCW:
Secure from above mdf slat securing bolts: 10-32 x1" button head socket cap
Secure from below mdf slate securing screws: 10-12x5/8"
Securing the Y rail to the qcw: M5 thread, 16 long, with a 5mm hex socket head.
