# Cutting thin gauge steel
**URL:** https://forum.onefinitycnc.com/t/cutting-thin-gauge-steel/14206
**Category:** Materials
**Created:** [July 18, 2022, 5:23pm UTC](https://forum.onefinitycnc.com/t/cutting-thin-gauge-steel/14206 "2022-07-18T17:23:54Z")
**Posts on this page:** 1
**Showing post:** 9
### Author: ![349iq2345](https://avatars.discourse-cdn.com/v4/letter/3/bb73d2/32.png) [@349iq2345](https://forum.onefinitycnc.com/u/349iq2345)
#### Post date: [July 19, 2022, 6:01pm UTC](https://forum.onefinitycnc.com/t/cutting-thin-gauge-steel/14206/9 "2022-07-19T18:01:47Z")
Hey Bill, hey Nick, hey all,
> [@Machinist](#):
> but from what I’ve read, there is basically no usable torque down at the lower RPM range. In other words, it may be able to spin @ 5000 RPM, but you couldn’t possibly cut anything with it.
The spindles [I refered to above](https://forum.onefinitycnc.com/t/cutting-thin-gauge-steel/14206/3) **do have maximum torque** at 1,500 rsp. 3,000 rpm, both the HPFD and HFPM series are designed to mill steel (see the torque/speed diagram in the datasheets).
However a spindle, which is an [induction motor](https://en.wikipedia.org/wiki/Induction_motor), can never compare to the router, which is a so-called [universal motor](https://en.wikipedia.org/wiki/Universal_motor) (a [commutated](https://en.wikipedia.org/wiki/Commutator_(electric)) series-wound motor). Only a spindle delivers constant high torque over its entire rated speed range (CT mode), while with the router, where the speed is dependent on the load, you only have an extremely narrow combination between usable torque and speed. Also a spindle is _never slowed down by any load_, unlike the router. If you want to know about the fundamental differences between the two, [see here](https://forum.onefinitycnc.com/t/how-do-you-ensure-your-model-translates-to-reality/13579/27#completely-different-types-of-motor-1)
You know I’ve often questioned how an experienced machinist like you, of all people, still works with this [hand trim router](https://www.makitatools.com/products/details/RT0701C) instead of a spindle. However, knowing the kind of work you do, that could be why you’re still happy with the router: first, perhaps that narrow torque/speed range happens to be one you need, and second, you’re probably very far from demanding much power from the motor 🙂, and of course thirdly because the spindles usually shown here are not rated for speeds below 6,000 rpm, as they target people who want to mill wood. However the hand trim router does not offer you low speeds either.
But I totally agree that if you put one of the spindles that are able to deliver high torque at very low speeds, and which are designed to mill steel, on the Onefinity, _the Onefinity is the limiting factor then_, at least if you [expect steel to be milled at this speed](https://youtu.be/osqX7iQEnuI?t=31) and at this [MRR](https://en.wikipedia.org/wiki/Material_removal_rate), as also [impressively shown here](https://youtu.be/NK0k38-6rEw?t=24). It is not a machine designed for it.
Do you remember when we discussed another interesting machine [here](https://forum.onefinitycnc.com/t/machinist-in-x-50/8159/10) and [here](https://forum.onefinitycnc.com/t/machinist-in-x-50/8159/18), we described the problem on the Onefinity with the router slid far downwards into the mount, the problem with the Z assembly in general, but also that the other machine refered to, which is sold as being a versatile machine perfectly able to mill steel, has [plain bearings](https://en.wikipedia.org/wiki/Plain_bearing) instead of [linear ball bearings](https://en.wikipedia.org/wiki/Linear-motion_bearing#Rolling-element_bearing) which would be more resistant against the high forces and vibrations when milling steel (by the way that machine had [some other advantages](https://forum.onefinitycnc.com/t/should-i-buy-onefinity-if-it-s-worth-it-guide-for-those-who-joined-the-forum-but-haven-t-ordered-the-machine-yet-how-to-buy-cnc-machine/7321/13))
> [@Machinist](#):
> Prior to moving from MI to AZ last year, I had one of these (but sold it), and it was pretty good for machining steel, although it wasn’t CNC.
> [https://littlemachineshop.com/products/product\_view.php?ProductID=3990&category=1387807683](https://littlemachineshop.com/products/product_view.php?ProductID=3990&category=1387807683)
What a nice machine. Why did you sell it? Your Onefinity Machinist isn’t really able to replace it (in no case in matters of milling steel)?
In this mill, [as they describe here](https://littlemachineshop.com/Info/hitorque_better.php), you have a type of motor [that is far superior](https://en.wikipedia.org/wiki/Brushless_DC_electric_motor) to the [commutated (brushed)](https://en.wikipedia.org/wiki/Commutator_(electric)) [universal motor](https://en.wikipedia.org/wiki/Universal_motor) like your hand trim router. A high torque from 100 – 2500 rpm, and totally silent, that’s ideal.
However the power they show here is sufficient for a mill. For a CNC, where you have much more speed of operation, it would have to be much stronger.
Note: If one should not only be interested in what spindle manufacturers offer to consumers and hobbyists, like Mechatron does, it is worth a look at this [manufacturers list](https://forum.onefinitycnc.com/t/spindles-lingering-questions/8643/6#high-frequency-spindles-in-europe-1).
_[View the full topic](https://forum.onefinitycnc.com/t/cutting-thin-gauge-steel/14206)._
