# European options?
**URL:** <https://forum.onefinitycnc.com/t/european-options/18346>\
**Created:** [January 24, 2023, 12:34pm UTC](https://forum.onefinitycnc.com/t/european-options/18346 "2023-01-24T12:34:37Z")\
**Post date:** [January 24, 2023, 12:55pm UTC](https://forum.onefinitycnc.com/t/european-options/18346/2 "2023-01-24T12:55:26Z")
Onefinity does not have any distributors in any country - they sell and ship.
Here is a link a search brought up regarding power in other countries:
> [@How To Switch The Controller from 110-220v](https://forum.onefinitycnc.com/t/how-to-switch-the-controller-from-110-220v/2125):
> Your Onefinity machine will come preconfigured for your countries power supply from the factory. In the event you need to change the voltage, you can do so inside of the controller. Inside the Onefinity controller is a Meanwell LRS-350-36 power supply. There is a red switch on the side that allows you to change from 110 to 220. You will not void your warranty by opening the controller, however, if you don’t have to open your controller, don’t open it stuck_out_tongue ALWAYS DISCONNECT POW…
As far as mass of Elite machines, I believe it would be similar to the regular machines based on the hardware differences highlighted. I do not think there are officially published specs yet as far as mass, but I did find this post from a European buyer of a Journeyman that may be helpful until you get other more definitive answers:
> [@Total packages weight for Journeyman and Woodworker](https://forum.onefinitycnc.com/t/total-packages-weight-for-journeyman-and-woodworker/10934):
> Dear All and Hello from Bahrain ! I wasn’t able to find the total weight (in kg or lbs) of packages (boxes) for each of Journeyman or Woodworker . Some topics say 135(lbs?) and other 160lbs (?) This will help me understand the shipment’s cost from other companies like DHL (when I simulate an order, the shipment fees show as 1600 USD which is quite expensive….) Many thanks.
_[View the full topic](https://forum.onefinitycnc.com/t/european-options/18346)._
