# Everything works until I hit Play - then nothing
**URL:** <https://forum.onefinitycnc.com/t/everything-works-until-i-hit-play-then-nothing/20468>\
**Created:** [May 6, 2023, 8:49pm UTC](https://forum.onefinitycnc.com/t/everything-works-until-i-hit-play-then-nothing/20468 "2023-05-06T20:49:23Z")\
**Showing post:** 16
**Post date:** [May 7, 2023, 10:01pm UTC](https://forum.onefinitycnc.com/t/everything-works-until-i-hit-play-then-nothing/20468/16 "2023-05-07T22:01:56Z")
Hey David,
> [@dbld\_58](#):
> 1. The controller software keeps reverting back to automatically update to the latest software - so I was back to 1.2.1 after a reboot. Even when I uncheck the box, it defaults back to a checked auto-update box.
really? Are you sure? Are you saying the controller now updates itself without your interaction?
Usually I suggest to uncheck this setting on the ADMIN page:
 ![OnefinityCNC_Disable_checking_for_new_firmware](https://us1.discourse-cdn.com/flex022/uploads/onefinitycnc/original/3X/3/a/3a371da62b23b5cc7c7b99d571de63ccc1a3fab1.png)
and then reload the CONTROL page.
> [@dbld\_58](#):
> 1. I am using the fusion post processor - On startup the machine will home as it should - then I set zero on my 5"x8" workpiece in the middlish front of the waistboard. So far so good. When I load my file, I get “over” on my toolpath. The graphic makes it appear as though my workpiece is the same size as the entire waist board and I moved zero making the workpiece too large. The workpiece in fusion is 5x8.
I am not sure if I understand. You have to make sure two things: 1. That the _workpiece zero_ in your 3D model is zeroed at the same point in your real machine’s workspace, and 2. that your 3D model is not bigger than the maximum workarea (816 x 816 mm for Woodworker model, 1220 mm x 816 mm for Journeyman). [See here for explanation](https://forum.onefinitycnc.com/t/error-keeps-popping-up/20471/5).
> [@dbld\_58](#):
> 1. lastly - it now goes to the rear right corner after completing a job…while I like this, could this be what’s causing some of the issue?
I don’t know why it goes to the right rear corner, but I would think it is because your g-code program tells it to do so.
_[View the full topic](https://forum.onefinitycnc.com/t/everything-works-until-i-hit-play-then-nothing/20468)._
