Have not been on the forum in some time. Working on CNC and it showed new firmware available. 1.1.1
It did an update. One thing that a happened is if you look at page 8 of the controller manual you should be able to select Metric or Imperial. There is no selection showing so it is Metric. Cannot change it. Strange. Just making a record for this on my system.
So I ran into the same thing after I updated. I went over and over the settings page trying to find where to change the setting. I gave up and just accepted that my display would be in metric and it would be something I would get over in time.
Much to my surprise, after about a week, I noticed that the setting was removed from the setup page because 1F conveniently put an imperial/metric toggle button on the top level of the main screen. It is right below the X/Y/Z position information.
Hope this helps.
