This is directly answered in the first post on this thread.
It does not. Weâre hoping to place it into the next firmware (will likely be a quick release).
Initial test of 1.2.0 looks good to me. I did the full sdcard flash method to upgrade from 1.1.1.
Wi-Fi and HY spindle settings worked as expected.
Screen âupside-downâ setting works nicely too.
USB gamepad worked as expected. (Iâm using unsupported Google Stadia USB controller so I have to tweak a config file to get Z axis control on the right-stick.
Be sure to follow step #11 of the sd image flash instructions to reset the defaults to your specific machine size.
As a bonus, I cleaned some sawdust out of my controller enclosure while it was open to access the sdcard!
I also then upgraded to the bbctrl-1.2.0-z-fix (1).tar.bz2 firmware version and that fixed the issue with selecting the newly uploaded file via the web interface. edit: nevermind. that still works or doesnât work intermittently.
Anything else specific you need tested?
I read above the web interface file upload not being selected is expected, but none-the-less i did some more testing. It appears that auto-selection of the newly uploaded .ngc works fine except for when the currently selected file is the top one in the list. Deleting that specific first file doesnât fix it. Selecting any other file except the first one before uploading a new one makes auto-select after upload work as expected. There is no error output in the browser javascript debug console.
hope this helps! please let me know if there is a more appropriate place to discuss debugging. github, etc⌠Thanks!
Thanks for this. Also lol: âAs a bonus, I cleaned some sawdust out of my controller enclosure while it was open to access the sdcard!â
Thanks !! already updated to the latest version,
Can a json backup from 1.0.9 be applied to 1.1.2?
yes you can do that with json.
Can we PLEASE put the date in the filename so we know which files are the newest? is there an update to 1.2 BETA other than the initial file?
Release candidates have just been updated. 1/27/23
Unless anyone finds any final bugs, these will be the public release versions releasing in a few days.
@PwnCNC VFD configurations will not make it into this version. We will be releasing a âhotfixâ patch once we finalize the configuration for it in the near future.
okay i loaded 1.2.1 final and the bug where you load a .NGC file and then load another (doesnât matter how many) it does not auto switch to the file just loaded. this has been documented in the forums already with video and honestly can cause a crash or worse if the operator is not paying attention.
also, upon loading and turning on my onefinity wireless controller it stated user pressed e-stop. which i didnât. i could not reproduce at this time.
hope your reading this.
another note on 1.2.1 final - not a huge issue but the touch screen is using 24 hour time, but 12 hour when i log in via network with a browser. i dont see where this can be changed. i prefer 12 hour
@OnefinityCNC - can you please look into this? I have documented with a video above and will not be able to upgrade firmware unless this is fixed.
I have never had this issue until this beta firmware.
Weâre investigating.
Can you post a video of this issue (and the file your loading) ?
Hi @ahandeman can you please help us with the video and file to replicate the issue on our end. Thanks for understanding. We will be looking into it as a priority.
Can you post a video of your issue?
Thank you for your help!
Of course I did a practice run before filming and i loaded 1 ngc file, then the second and it worked fine. then the third file loaded but it stayed on the second file.
now i cant get it to do it again. David in this chat posted a video of exactly whats happening and its not file dependant but it is random.
Ill keep trying
I got it to do it several times and here is a video. Sometimes itâs on the second load sometimes the third or even fourth.
I have the video but it wont let me upload video files here. here is a one drive link
