Gen 1 BB Controller Z-slider moving in random directions & losing homing/positioning
Howdy,
My Z-slider recently started behaving strangely. When I jog Z+ or push the joystick up, there is about a 50/50 chance the Z-slider will travel in the wrong direction (down instead of up).
A few additional details:
  • Losing Position: It has also started losing its Z-zero / home position during runs.
  • Motor Sound: The Z motor has started sounding noticeably different/rough lately.
  • Wiring: I inspected all cable connections and extension wires; everything looks clean and intact. The factory hot glue is still intact on the connectors from when I bought the machine about 3–4 years ago.
I’ve attached a video showing the issue in action. Has anyone run into this, or could it be a failing motor, or stepper driver issue? Thanks for any advice!
Jayson
Try switching the x and z cable at the controller (when it is off) see if the problem moves to your x. If it moves to x then you know it is something behind the y stepper/cables. If it stays on Y then you know you are hunting cables forward.
That’s a good way to narrow it down without replacing parts at random. I’d definitely power the printer off before swapping anything, then check whether the fault follows the cable or stays with the Y axis. If it follows the cable, the cable or connector is the likely culprit.
On a BB controller, this is 100% of the time a bad wire/wire connection.
3a and 3b on this faq will identify which wire(s) and get you fixed up:
