# Home, zero, load, run then z hops to new zero
**URL:** <https://forum.onefinitycnc.com/t/home-zero-load-run-then-z-hops-to-new-zero/9094>\
**Created:** [November 23, 2021, 4:32pm UTC](https://forum.onefinitycnc.com/t/home-zero-load-run-then-z-hops-to-new-zero/9094 "2021-11-23T16:32:16Z")\
**Showing post:** 3
**Post date:** [January 7, 2022, 8:45pm UTC](https://forum.onefinitycnc.com/t/home-zero-load-run-then-z-hops-to-new-zero/9094/3 "2022-01-07T20:45:28Z")
Hey Milank,
> [@milank](#):
> Could this conceivably be related to wire connections? [Z Axis Changes During Cut - #6 by Dunlow](https://forum.onefinitycnc.com/t/z-axis-changes-during-cut/2266/6)
I would also check [loose Z coupler (in topic “Roughing bit increases depth ruining the work”](https://forum.onefinitycnc.com/t/roughing-bit-increases-depth-ruining-the-work/8730/4)
- check Z [Ball Screw Coupler](https://youtu.be/wXs3e-eecFk?t=148) could be loose
and then
- check Z [Ball Nut Set Screws](https://youtu.be/pHmj8YS3eSg?t=50) could be loose
![Onefinity __Z-Slider__ Ball_Screw_Coupler __and__ Ball_Nut](https://us1.discourse-cdn.com/flex022/uploads/onefinitycnc/original/2X/f/f924774db50734f1212e87ded6278559118f38cd.png)
_[View the full topic](https://forum.onefinitycnc.com/t/home-zero-load-run-then-z-hops-to-new-zero/9094)._
