# Homing Estop issue
**URL:** <https://forum.onefinitycnc.com/t/homing-estop-issue/26912>\
**Created:** [May 8, 2024, 6:55pm UTC](https://forum.onefinitycnc.com/t/homing-estop-issue/26912 "2024-05-08T18:55:23Z")\
**Post date:** [May 8, 2024, 9:30pm UTC](https://forum.onefinitycnc.com/t/homing-estop-issue/26912/2 "2024-05-08T21:30:29Z")
Hey Mark,
> [@daddyaddi](#):
> Why does the Estop come on when I home my Woodworker?
do you mean on the buildbotics-derived Onefinity Controller on the PRO/X-50/Original Series? A “Woodworker” model exists as Elite, PRO, X-50, and Original Series.
If so, and you get a limit error after homing, then…
> [@Continually getting an X under error. Any help to fix greatly appreciated](https://forum.onefinitycnc.com/t/continually-getting-an-x-under-error-any-help-to-fix-greatly-appreciated/21376/2):
> …as long as you have not created a g-code toolpath of your own, uploaded and selected it in the machine, and probed or manually set your workpiece zero coordinate, this is not an issue and can (must) be safely ignored.
> _ **If** _ you have created a g-code toolpath of your own, uploaded and selected it in the machine, and probed or manually set workpiece zero coordinate, then this error tells you that your g-code toolpath wants the machine to mill outside its workarea, which will in no case go. In this case, either your 3D model is too big, or you’ve probed or set manually your workpiece zero coordinate in the wrong position.
> This support document may help you:
> - [Help! My Toolpath says ‘Under’ or 'Over"! (with videos)](https://forum.onefinitycnc.com/t/help-my-toolpath-says-under-or-over-with-videos/1982)
If you have an Elite Series, the reason is probably different. Check motor cabling.
_[View the full topic](https://forum.onefinitycnc.com/t/homing-estop-issue/26912)._
