Has anyone had joystick issues since the latest firmware update. I am using an old XBox 360 controller that was working well until the update. Now it is completely unresponsive. I tried fiddling with the options and changing controllers but it still wont jog the machine anymore. I may have to go buy a new controller its just a shame since it was working well and still works when I use it on the X-Box. Any ideas?
I am having a similar issue with 1.1.1. The X box clone controller that Iām currently using was working fine before I upgraded to the latest revision. the unit i have is made by Voyee. Iām guessing I may have to used a different controller such as the Logitech unit in the pulldown menu.
Thereās currently an issue with Xbox 360 controllers that has been fixed internally and we will release a beta soon for everyone to test. Beta should be in the ābeta firmwareā in the next few days.
The Xbox 360 controller had an unexpected @ character that made the python code freak out.
I had this issue yesterday, it had a random lag and sometimes wouldnāt stop moving. my controller came with my onefinity and was working great until yesterday. I use 1.1.1 firmware.
No, I will download immediately, thanks for the headsup.
Apologies in advance for the rant. The Mechanics of this machine are second to none but sadly the whole connectivity issues Wifi range, Joystick ⦠is really spoiling what is an amazing experience, I really hope these are being looked into seriously.
So just installed 1.1.2 Alpha and in a quick check the following can be reported:
Initially it homed to Y= middle of the machine X=0 and called it home
The joystick moved freely then the machine got stuck and would not move to the left (standing in front of the machine)
I have changed the batteries and removed the USB dongle and swapped the USB port
It will not move to the left farther than where it homed in place because it thinks that is where the end of the rail on the left is. Itās not a joystick issues or 1.1.1 firmware issue, itās simply an adjust stall homing issue (that has been something that will need to be done since the inception of the machine) corrected by this video here; Adjusting Stall Homing On The Onefinity CNC - YouTube
Thank you, I adjusted the stall homing when I first received the machine and it been working great ever since, until this update.
The 1.1.1 suddenly kept homing without any input, it did this about 4 times over possibly 20mins or so! it could have been a significant lag but I cant tell for sure. The āhomeā it did on its own actually did home properly!
I have now gone to 1.0.9 and I am glad it didnāt revert the screen back to before the flip.
-Home works perfect now
-Joystick issues gone
File gets uploaded easily
Laptop connects easy over wifi
either I am very lucky or the updates need a bit of attention, who knowsā¦
Video and repeatability is how weād identify bugs and fix themā¦so any time you find a bug, video it, try to be able to repeat it, and post it here so the developers can see it and replicate it themselves. Without any users doing this, they wonāt be able to fix anything.
