# Keeping zero position
**URL:** <https://forum.onefinitycnc.com/t/keeping-zero-position/14115>\
**Created:** [July 13, 2022, 1:47pm UTC](https://forum.onefinitycnc.com/t/keeping-zero-position/14115 "2022-07-13T13:47:13Z")\
**Showing post:** 19
**Author:** ![bumps](https://sea2.discourse-cdn.com/flex022/user_avatar/forum.onefinitycnc.com/bumps/32/3445_2.png) [@bumps](https://forum.onefinitycnc.com/u/bumps)\
**Post date:** [July 19, 2022, 8:44am UTC](https://forum.onefinitycnc.com/t/keeping-zero-position/14115/19 "2022-07-19T08:44:18Z")
Yes it is easy, you must, once you have set your zeros, make a note or take a picture of your offsets. Then if you want to get back to the set position after you have shut down your machine follow these steps;
1 restart and home your machine.
2 open the MDI tab
3 type, g01x… y… The dots are your offsets that you made a note of.
4 press enter.
You should now be within 0.0002 of your last settings.
Hope this helps
_[View the full topic](https://forum.onefinitycnc.com/t/keeping-zero-position/14115)._
