# Keeping zero position
**URL:** <https://forum.onefinitycnc.com/t/keeping-zero-position/14115>\
**Created:** [July 13, 2022, 1:47pm UTC](https://forum.onefinitycnc.com/t/keeping-zero-position/14115 "2022-07-13T13:47:13Z")\
**Showing post:** 50
**Post date:** [March 13, 2023, 8:20pm UTC](https://forum.onefinitycnc.com/t/keeping-zero-position/14115/50 "2023-03-13T20:20:50Z")
Hey JDog,
beautiful fixtures / jigs!
I think reducing the use of the touch probe to only once per bootup period because you have a fixed jig is something that really saves time. I think when using this, it is important that you can ensure accurate positioning and clamping of the workpiece at the jig, I mean the faces would need to be perpendicular and first of all perfectly parallel to machine axes. As [Dr-Al mentioned the other day](https://forum.onefinitycnc.com/t/grid-lines-on-spoil-board/3213/25), when you mill the faces of your angular jig _with the machine itself_, the parallelity to the machine axis is absolutely perfect and reliable.
Another way to achieve positioning repeatability is to [retrofit inductive proximity sensors](https://forum.onefinitycnc.com/t/controller-software-tool-change-location-0-0-g54-g55-g56/10052/14) to decommission the stock [stall homing](https://forum.onefinitycnc.com/t/how-common-are-missed-steps/18352/8). This brings perfect positioning repeatability. With inductive limit sensors, you can rely on the absolute _machine coordinates_, which means if you want to move to a specific point, you could do that with motion commands and a coordinate, and it would accurately be the same position everytime, even after shutdown or power outage.
A positive side effect of limit sensors is that you can [square the machine](https://forum.onefinitycnc.com/t/what-do-i-do-first/18349/6) **without** unbolting and repositioning main parts of the machine. You can simply move the sensors a bit. Elite Series with Masso G3 Touch use a comparable way to achieve its auto-squaring.
_[View the full topic](https://forum.onefinitycnc.com/t/keeping-zero-position/14115)._
