# Machine has gotten jumpy (solved, loose motor coupling)
**URL:** <https://forum.onefinitycnc.com/t/machine-has-gotten-jumpy-solved-loose-motor-coupling/26708>\
**Created:** [April 27, 2024, 5:20am UTC](https://forum.onefinitycnc.com/t/machine-has-gotten-jumpy-solved-loose-motor-coupling/26708 "2024-04-27T05:20:52Z")\
**Post date:** [April 27, 2024, 6:12am UTC](https://forum.onefinitycnc.com/t/machine-has-gotten-jumpy-solved-loose-motor-coupling/26708/2 "2024-04-27T06:12:56Z")
Hey Alex,
> [@760woodworking](#):
> Ran same program 10+ times all of a sudden it starts getting jumpy and making bad parts.
> same hole 2.0 dia 2 times separate depths rough depth is fine finish depth which is .300 deeper has a bad step in it and now my cutout has the same and the machine is jumping I can see it shaking. everything is oiled and smooth. Even using the joystick it is jumpy in the same area
You don’t give much information.
Which axes are affected?
How big is the portion of axis travel where the problem appears?
Which machine are you using? As a hobbyist Sherlock Holmes, I deduce: Joystick = Original/X-50/PRO machine. But which one? Do you already have a PRO Series that already has the 30 mm drag chains from Elite Series, or the old models with [lacking strain relief](https://forum.onefinitycnc.com/t/strain-relief-for-x-gantry-molex-connectors/11461) and where [the curly Z cable](https://www.onefinitycnc.com/product-page/z-axis-curly-cable-for-all-sized-machines) that can break internally after a year or so.
How long have you been using it?
I would check the points in this support document one by one:
- [Troubleshooting: Rail is getting hung, stuck, grinding, or moving in opposite direction (x35/x50 machines)](https://forum.onefinitycnc.com/t/troubleshooting-rail-is-getting-hung-stuck-grinding-or-moving-in-opposite-direction-x35-x50-machines/10826)
Also have you ensured accurately that your machine is [**rectangular** (“squared”) (➪ _bar gauge_) and **coplanar** (“not twisted”) (➪ _fishing line method_)](https://forum.onefinitycnc.com/t/what-do-i-do-first/18349/6)? If it is not adjusted, Y movement can block. Coplanarity of the machine is often underestimated (machine not being twisted).
_[View the full topic](https://forum.onefinitycnc.com/t/machine-has-gotten-jumpy-solved-loose-motor-coupling/26708)._
