Aiph5u
(Aiph5u (not affiliated with Onefinity))
21
Hey Russel,
The air flow of the air cooling system of the Makita hand trim router sucks the air from the back (upper side) of the tool and lets it out on the collet side.
The covers protect from bigger particles but not from dust.
You disassembled this hand tool. Where did you see wood dust accumulated inside, along the described air flow?
One thing is clear, if you have wood dust in the bearing, it has not been sucked by your dust extraction system.
Better suction? Scrap the shop vac and go for a wall mount dust collector? What do most people use?
Better dust boot?
Spindle? Will a spindle be any better? Are spindle bearings sealed any better?
I didn’t notice more dust on one side or the other of the bearing after disassembly. BTW: The top smaller bearing is fine.
I would take very thin cuts with the flattening bit. After a flattening there would be no dust.
I bought Mechatron’s cooling station, but I set it in a cabinet beneath the CNC. The cabinet has no doors and is 24" deep, 60" wide. I could easily have positioned it further from the cabinet sides (and now have done so). I hope my problem was that the fan (at the back) and air intake (one of the sides) were both too close to the cabinet.
Aiph5u
24
I have no personal experience with air-cooled spindles. One thing is sure, on a water-cooled spindle, there is no fan and no air flow through the device, and the cooling capacity does not depend on spindle rpm (like it does on air-cooled motors).
Aiph5u
25
Hey David,
then you have the same cooling station than me. But I don’t think you need anyone to tell you that you made a mistake by limiting the ventilation of your cooling station
Why did you enclose it into this cabinet? Usually you would have to make sure heat can get away
Will you report what Mechatron replied? In the spindle manual it says 10 °C – 30 °C is allowed range and at 40 °C there should be the alarm triggering. In the cooling station manual it say it’s sufficient for spindles up to 5.0 kW.
Yes, I’ll pass along what they tell me.
Why in a cabinet? I wanted it beneath the CNC, both to avoid a tripping hazard and to mitigate dust entry. We could call it a cabinet or just a shelf, since it’s such a large space (20 cubic feet), open along the entire face. Either way, I should have given it more distance from the sides, and that’s easy to do.
The temperature never rose above 31 C, and the alarm never sounded. I assume the primary problem was ventilation, but I can’t be certain that faulty bearings were not the cause.
Certainly the protections (the alarm and the capacity to tolerate up to 40 C) were not sufficient to prevent damage.
Aiph5u
28
Hey David,
usually the best would be if the heat can flow upwards from the outlet. And of course that it can get fresh air to its inputs
Cooling fluid level confirmed within specifications. The open face (during usual operations) is about 10" from a wall. But the most serious (former) problem was that the cooling station was turned 90 degrees, with the fan output toward the longest wall seen int the image. One side was much closer to the wall that separates it from the VFD enclosure (right side of the image). Attached is a photo of the front of the cabinet. The front and back portions are separated by a panel that runs the length of the cabinet.
Thank you. I made a torsion box, wrapped with ash wood taken from a tree my neighbor felled. The base is simple cabinetry made from a red oak I had to take down several years ago. The design was inspired by an outfeed table on YouTube: DownToEarth Woodworking.
I’m an amateur woodworker before I’m any kind of CNC expert.
I am interested in knowing more about replacing that bearing. Do you need any special tools to do this repair? I am thinking I am going to order a backup Makita from Mr. Bezos. I have had my OF since March and would not be surprised if I have the same situation developing.
Removal:
My gear pullers did not fit between air fins and the bearing. Too tight. So, I placed 2 hardened steel strips that DID FIT between air fins and bearing, placed it on a vise and carefully pounded it out with a hammer.
Install:
A vise and a 18mm deep socket with a hammer. Pound on socket to push on new bearing.
These are trim routers, meant to run for short on and off cycles, probably never intended to run non stop. The fact more don’t die quickly is amazing actually.
Buying this, I’d buy it at a big box and slap on the like 2 year extended warranty, I think it is $12. When it dies, you take it back, get a new one in exchange, and optionally buy another $12 warranty.
My opinion, just move up to an 80mm spindle. Designed for the task. No brushes. Fully controlled by software. Water cooled are basically sealed, so no worries of packing debris into them as a air cool can. Skip 65mm spindles, as they conflict with the stock mount.
@Cryptonym Big Box store is not a bad idea. I bought both of my Makitas from the Evil Empire and had to take it to a warranty repair center. After a few times (OK, six times???), they ask you how you’re using it and unless you outright lie, they tell you they won’t repair it anymore because a CNC is not an applicable use. The Big Box store might not have time to care and just swap it out.
Moving to an 80mm water-cooled spindle is the way to go but if can be complicated (if you buy the parts yourself and attempt to build) or sort of expensive if you buy a kit. Here’s my scenario: 80mm Z20 Mount ($375), 80mm PwnCNC spindle ($900), adding a 220V circuit ($200-$400??), Misc:CableMgt,Hoses etc. ($300??) and how many hours?? It’s not a simple path (I’m just getting started) but when you are done, I’m thinking we’ll all have one hell of a machine.
And maybe even some updated firmware!!! (It sounds like we are getting close.)
Aiph5u
38
Hey Jim,
you are quite right not to gloss over the circumstances under which one reaches the installation and use of a three-phase induction motor with VFD (aka spindle), even if that is the superior technology for the purpose.
That’s why it’s even sadder that there are many plug-and-play milling motors out there that just won’t burn out when you use them in a CNC, in fact, they’re made for it – but the Onefinity still has no mount for these.
