Question - are their optimized settings for the Buildbotics controller that have been proven over time? I did purchase a new SanDisk micro SD card and flashed it with 1.2.1 and inserted it into the controller and then did a config reset. I’ve heard others commenting about changes to the config files, but nothing solid coming from OneFinity on this.
On 1.09 I was having a probing problem that sounds similar. Solution was to do a reset of the software configuration within the Onefinity. After that the problem went away. I went back to my old settings and it still worked (reminder you need to tell it what model of CNC you have). No idea of what went wrong, but it was now fixed. You may want to try the same if you haven’t already.
Hi @Seamartin00 : Thanks for your feedback. Can you please help us with below information?
Can you able to replicate the issue?
May I know the version you have upgraded from?
If you able to replicate the issue, Can you please connect with us to collect the logs? to understand the issue is specific to your machine or Bug?
Well I could replicate it every single time but I’ve since removed the SD card and did a reflash as stated above so there are no other files in my machine at the moment. I’m not 100% sure which firmware I was using anytime an update pops up I usually do it so whatever the last stable update was is probably what I was on, sorry I know that’s not helpful. I can say that I would select the file off of my USB stick It would process it like normally would but the file that ended up showing up that was getting ready to be carved was a completely different file and it was the same file every time. Before I reflashed I removed all of the files from my machine and the new file loaded up fine because it had no other file to default to, but I’ll let you know if it keeps doing it because Ive got a few carves going tonight to get track on track.
Andy,
Please ping @DEV_D with your issue (software devs). This is the first we’ve heard of anything with VFD. One note, although VFD’s are in the software, as I’m sure you are aware, we’ve stated since inception that spindles are 100% not supported, so this potential ‘bug’ will be lower in the issue queue.
I just had the same issue, exact same issue with probing not completing. And you are correct, it did capture the correct values, it was just the dialog box did not go away.
I was able to capture the last step, and you can see the dialogue just freezes.
With respect to support. I understand that you do not support VFDs but the onefinity software supports modbus communications, has preconfigured and custom options along with supporting PWM comms for use with lasers. When modbus comms work in one version then not in a another it is, in my opinion, a support issue. It would be a poor showing if 1F could not support modbus.
Okay so. I was trying to get video of loading a file that wouldn’t generate the 3d view. But instead I got a video of the firmware NOT going to the loaded file… here’s the video
Go to firmware home screen and navigate to general section
Select Upgrade via file option
Select the tar.bz2 file from USB drive
It will update the firmware with latest patch.
Select the G-Code which you want to run
Again, navigate to General tab (Under admin section)
Click on View report
It will open in separate tab – kindly save the log into USB drive
Continue your process of cutting the wood Or Job
If you see the issue/Error. Kindly go back to the tab and refresh and save the logs
Note : Issue might not happen at the first time, incase it happened after 1st time kindly repeat the steps from 7 to 12. Kindly share the logs to Developer@onefinitycnc.com for us to investigate the issue. Much appreciated your support here.
