Do you have the probe block correctly oriented? If doing xyz probing it’s oriented with the 2 raised edge walls down and pushed against the corner. You need to prove in the corner of the block where the inscribed circle is.
If just probing just the z height the two raised side walls need to be facing up & the block can be anywhere on the material (or spoil board if zeroing from the base). You can zero from any point on the block except the edge walls. Those edge walls are about 1/4” and might be the cause of your issue if they’re on the material.
I have a Masso - so take some of what i say with a grain of salt…
It appeears on one screen you zero’d on the material and it reads zero
It appears on the next screen you used the block and it reads -.787 - which doesn’t correspond to 15.1mm either (roughly 0.6")
When you place the block “Upside down” are you probing Z only?
I would use it more on a known regular item and see if there is any difference - or something you may have used it on in the past that worked - to make sure it hasn’t ded in the meantime
My two cents-
Create a simple straight endmill cut toolpath of 0.125 depth of cut from material top
Take a piece of scrap and measure using a piece of paper from the top of the material to the endmill.
Run your program and check the depth of cut using a digital caliper
If its accurate then its not Z screw or the coupler. Could be the steps on the motor.
If not check the coupler and ballnut
Ok good
The only other thing would be how high is the bit above the probe when you start probing?
I found there seems to be a sweet spot around an inch above that works best.
Don’t know if there’s a setting for that or not in the probing cycle.
