Pwn spindle stopped?
PWN Spindle during break-in stopped spinning. Ther was no noise, no heat, no smell and no indication of mechanical failure at all.
Can the MASSO be bypassed to check directly through the VFD?
Thanks in advance!
On the side of the vfd should be a switch to change from manual to masso controlled.
If you have v5 (or whatever the latest is) – earlier versions don’t have the switch. I’m not entirely sure when they introduced it.
Regardless, you can bypass the Masso with the right setup on the VFD.
