# Set workpiece zero to machine bed (=to vacuum table, trying to save vacuum table)
**URL:** <https://forum.onefinitycnc.com/t/set-workpiece-zero-to-machine-bed-to-vacuum-table-trying-to-save-vacuum-table/28026>\
**Created:** [July 26, 2024, 11:04pm UTC](https://forum.onefinitycnc.com/t/set-workpiece-zero-to-machine-bed-to-vacuum-table-trying-to-save-vacuum-table/28026 "2024-07-26T23:04:30Z")\
**Showing post:** 3
**Post date:** [July 27, 2024, 3:45am UTC](https://forum.onefinitycnc.com/t/set-workpiece-zero-to-machine-bed-to-vacuum-table-trying-to-save-vacuum-table/28026/3 "2024-07-27T03:45:37Z")
Hey gander,
> [@gander](#):
> The bottom line is I want to try and insure that my vacuum board never gets cut, if possible. It’d be more traumatic than swapping out throwaway pieces of MDF.
it is not possible to set a fixed minimum Z height, with no CNC machine, because it depends on the length of the bit, and where you probe Z. But if you always set your _workpieze zero coordinate_ to the bottom of your virtual 3D model, you always probe workpiece zero from the machine bed, which would be the vacuum bed here (flip XÝZ touch plate over in this case, see XYZ touch plate installation & instruction video). In this case the bit end will not go lower than the vacuum plate.
> [@Setting z height correctly?](https://forum.onefinitycnc.com/t/setting-z-height-correctly/26756/5):
> > [@Setting z height correctly?](https://forum.onefinitycnc.com/t/setting-z-height-correctly/26756/4):
> > Followup question. If I wanted to set the Zero Height from the top of the wasteboard (aka “bottom of the workpiece”) do I do that using the Onefinity probe
> In this case you use the XYZ touch plate upside down, on machine bed. Thickness of the touch plate will be subtracted automatically.
> > [@Tool path Starts at Origin (bottom left corner of material)](https://forum.onefinitycnc.com/t/tool-path-starts-at-origin-bottom-left-corner-of-material/19198/2):
> > Support videos:
> > - [How to attach and use the XYZ Touch Plate](https://www.youtube.com/watch?v=p84CB9iMl6Q&list=PLlCbxVoOUWYVsInAIXHKKvWGEqJqoELFD&index=4)
> > - [Manually Setting X,Y,Z Zero on the Onefinity CNC](https://www.youtube.com/watch?v=5mhpzL1sAwo&list=PLlCbxVoOUWYVsInAIXHKKvWGEqJqoELFD&index=34)
> > - [How to Probe a V-Bit on the Onefinity CNC](https://www.youtube.com/watch?v=G2MfNTguvKg&list=PLlCbxVoOUWYVsInAIXHKKvWGEqJqoELFD&index=35)
> > - [Onefinity Touch Probe Fine Tuning](https://www.youtube.com/watch?v=jsiKYUPfeUM&list=PLlCbxVoOUWYVsInAIXHKKvWGEqJqoELFD&index=7)
> > Accessories
> > - [Onefinity 3-Axis Touch Probe](https://www.onefinitycnc.com/product-page/onefinity-3-axis-touch-probe)
> > - [Replacement cable (5 or 8 feet)](https://triquetra-cnc.com/product/magnetic-ground-connector-wire-banana-plug/)
For the protocol: Changed topic title and category accordingly (instead of “Do not pass Z value”, simply “Probe Z from bottom of workpiece”. Category: Topic applies to all types fo CNC machines.)
Welcome to the forum!
_[View the full topic](https://forum.onefinitycnc.com/t/set-workpiece-zero-to-machine-bed-to-vacuum-table-trying-to-save-vacuum-table/28026)._
