# Speed control dial does nothing on VFD (SOLVED) & VFD wiring
**URL:** <https://forum.onefinitycnc.com/t/speed-control-dial-does-nothing-on-vfd-solved-vfd-wiring/12831>\
**Created:** [May 1, 2022, 9:04pm UTC](https://forum.onefinitycnc.com/t/speed-control-dial-does-nothing-on-vfd-solved-vfd-wiring/12831 "2022-05-01T21:04:11Z")\
**Showing post:** 6
**Post date:** [May 1, 2022, 10:19pm UTC](https://forum.onefinitycnc.com/t/speed-control-dial-does-nothing-on-vfd-solved-vfd-wiring/12831/6 "2022-05-01T22:19:15Z")
Hey Jay,
I was in error when I said that I did not read the manual. It seems to be the same VFD as in [this thread from the other day](https://forum.onefinitycnc.com/t/huanyang-vfd-to-controller/8589/16). The manual, is it identical to [this one](https://www.omc-stepperonline.com/download/VFD%20manual%20datasheet.pdf)?
If yes, have you set F002 to 3 and F001 to 0?
 ![V70_Series_Manual__No.5_Function_List_P015_table-_mark_on_potentiometer](https://us1.discourse-cdn.com/flex022/uploads/onefinitycnc/original/2X/8/8eea3e4b130b881d820d36d1d3e8eb4b922237cb.png)
![V70_Series_Manual __No._6_Function_List_P028__ F002_Frequency_setting_selection](https://us1.discourse-cdn.com/flex022/uploads/onefinitycnc/original/2X/8/8f4557ae6804c47492b0d5ef6a8013381641fb70.png)
**First of all,** have you set the mandatory settings according to your spindle manual:
1. Rated spindle voltage
2. Rated spindle current
3. Number of magnetic poles of spindle
4. Maximum spindle speed
5. Minimum spindle speed
_[View the full topic](https://forum.onefinitycnc.com/t/speed-control-dial-does-nothing-on-vfd-solved-vfd-wiring/12831)._
