# Spindle power for cutting guitar bodies
**URL:** <https://forum.onefinitycnc.com/t/spindle-power-for-cutting-guitar-bodies/20383>\
**Created:** [May 1, 2023, 9:29am UTC](https://forum.onefinitycnc.com/t/spindle-power-for-cutting-guitar-bodies/20383 "2023-05-01T09:29:38Z")\
**Showing post:** 3
**Post date:** [May 1, 2023, 10:20am UTC](https://forum.onefinitycnc.com/t/spindle-power-for-cutting-guitar-bodies/20383/3 "2023-05-01T10:20:49Z")
PS: [Here you can see a spindle driven to its limits](https://forum.onefinitycnc.com/t/incorrect-or-missing-data-on-cheap-chinese-vfds-and-spindles/18909/30). It’s a Jianken 2.5 kW but as Jianken writes the so-called apparent power on their nameplates, the mechanical power should be someting around 1.8 kW. It is rated 6.6 A but you can see in the video that it is driven to 10 A (on longer duration the VFD would trip then). Also you can see a link to [milling _black locust_](https://forum.onefinitycnc.com/t/largest-clearance-bit-the-makita-router-can-use/13687/12) with a 8 mm _roughing bit_ with a [6.6 kW spindle](http://cnc.a-ueberbach.de/elektro/hsd-66-kw-fraesspindel-sie-dreht/).
PS2: Pine is a soft wood, but its knotholes and the dark part of growth rings is denser and harder than a hardwood. That’s why softwood timber with knotholes is only present in the furniture industry since the advent of [HSS](https://en.wikipedia.org/wiki/High-speed_steel). Conifer knotholes made hardened carbon steel (as used in handplanes and chisels until the 1950s) dull or break it.
_[View the full topic](https://forum.onefinitycnc.com/t/spindle-power-for-cutting-guitar-bodies/20383)._
