# Stepper motor brake
**URL:** <https://forum.onefinitycnc.com/t/stepper-motor-brake/13256>\
**Created:** [May 24, 2022, 10:45pm UTC](https://forum.onefinitycnc.com/t/stepper-motor-brake/13256 "2022-05-24T22:45:46Z")\
**Post date:** [May 25, 2022, 12:12am UTC](https://forum.onefinitycnc.com/t/stepper-motor-brake/13256/2 "2022-05-25T00:12:16Z")
Hey Carl,
(continuing the discussion from [Shutdown on wallmount](https://forum.onefinitycnc.com/t/shutdown-on-wallmount/13245/5))
the brake is mounted on the rear of the stepper, not on the front.
- [I already have a motor, can I buy brake and attach on motor?](https://www.omc-stepperonline.com/support/s9/i-already-have-a-motor-can-i-buy-brake-and-attach-on-motor)
In case you cannot retrofit the brake to the stepper, you can also replace the stepper with one that already has a brake mounted. The [X stepper of Journeyman](https://forum.onefinitycnc.com/t/motor-size-for-journeyman/11126/3) is [23HS30-2804S](https://www.omc-stepperonline.com/nema-23-bipolar-1-8deg-1-9nm-269oz-in-2-8a-3-2v-57x57x76mm-4-wires-23hs30-2804s) ([datasheet here](https://www.omc-stepperonline.com/download/23HS30-2804S.pdf)) and the corresponding model with brake is [23HS30-2804D-B200](https://www.omc-stepperonline.com/nema-23-stepper-1-9nm-269oz-in-w-brake-friction-torque-2-0nm-283oz-in-23hs30-2804d-b200) ([datasheet here](https://www.omc-stepperonline.com/download/23HS30-2804D-B200.pdf), [brake datasheet here](https://www.omc-stepperonline.com/download/SWB-03.pdf)).
To be exact, Tom @TMToronto picked up his X-50 rail at the Onefinity Factory and reported the stepper is [23HS30-2804S- **C1**](https://forum.onefinitycnc.com/t/motor-size-for-journeyman/11126/3) but @onefinitycnc [says here it’s a 23HS30-2804S- **RV**](https://forum.onefinitycnc.com/t/differences-between-x-50-rails-upgrade-and-x-35-rails-standard/6033). Since I don’t have the machine here I cannot say immediately what stepper is found on mine.
What you also would need is a power supply with 24 V 500 mA for the brake.
EDIT: Just saw that the model with brake does not correspond because the one with brake has shaft diameter 8 mm while the other has shaft diameter 6.35 mm. Possibly manufacturer has motor w/brake with correct shaft diameter available. Will have a look at the weekend. If not, we got to get another [coupler](https://www.onefinitycnc.com/product-page/high-torque-shaft-coupler-6-35mm-to-10mm).
_[View the full topic](https://forum.onefinitycnc.com/t/stepper-motor-brake/13256)._
