This FAQ is to troubleshoot the ‘wifi module not found?’ on Elite Masso Machines.
Turn off MASSO and remove the top cover from the G3 inside the
cabinet. -
Unplug the WiFi module from the main board and plug it back in.
Make sure the pins are aligned correctly. This will effectively
clean the pins and ensure a good contact. -
Repower MASSO and check to see if it can now see the WiFi module.
If the WiFi module is still showing as WiFi module is not found, the WiFi module is faulty.
