UPDATED 12/16/2020
Here releases of the Post Processors for Vectric. You will need to manually install these. For these, you will need to zero z before running a file using the probe button or manually zeroing z using the 0 (zero) button.
Onefinity (Inch).pp (5.0 KB)
Onefinity (MM).pp (5.1 KB)
There are two methods for adding post-processors to the Vcarve/Aspire software. Depending on the computer settings and web browser being used, downloading the post-processor .pp files may require right-clicking the link and selecting âSave Link asâ or âSave target asâ.
Step 1 : Downloading the Post-Processor:
- Left-click the post-processor link to download the .pp file
a. On most computers, the downloaded .pp file will be saved in the âDownloads folderâ
b. Downloading the post-processor .pp files may require right-clicking the link and selecting âSave Link asâ or âSave target asâ
Step 2 : Adding post-processors to Vcarve/Aspire
Method 1:
Open the âDownloadsâ folder or the location the post-processor was saved on the computer
Open Vcarve/Aspire
Select File, then Open Application Data folder
a. There should now be two windows open on the computer screen
Right-click on the post-processor .pp file and select âCopyâ
Right-click the PostP Folder, and select âPasteâ
a. For a shortened list of post-processors, paste any .pp file(s) that are regularly used into the MyPostP folder
Close Vcarve/Aspire
Open Vcarve/Aspire, the post-processor drop-down list will now but updated
Method 2:
Open Vcarve/Aspire
Select âCreate a New Fileâ
Select Toolpaths at the top, then âInstall Post Processorâ
a. A pop-up window will appear
Navigate to the âDownloadsâ folder or the location the post-processor was saved on the computer
Select the .pp file, then select Open
Close Vcarve/Aspire
If youâre running an older version of Vectric, some may give errors for the âjetâ.
Try using this post processor (ONLY if the above version does not work)
Onefinity (Inch) no jet.pp (4.4 KB)
