What causes the final pass around the letters in my pocket cut to leave this slightly lower cut ? Roughing pass with .25 in downcut bit, finish pass with 1/8th inch downcut bit, everything looks good til the final pass and it finishes with the deeper cut?
Make sure you’re probing your Z at the same spot after bit changes. For your initial Z, don’t probe at a location that will be carved away. Sometimes the board may not be perfectly flat, so if you probe at different locations there could be a slight difference.
