Selling a moderately used woodworker X-35 with stiffy rail. I have not used it in about 6 months due to a change in priorities. The machine worked perfectly the last I used it, but could probably use a cleaning/standard maintenance. It comes with an assortment of bits (some lightly used, some with more use but still plenty of life left on them), touch probe, and Makita router. The router speed dial started to get lose and slip during use which is why there is a toothpick holding it in place. I do also have the original boxes the CNC came in. The table can be taken as well if desired for no additional cost. This will be for pickup only near 78130 area code. Looking to get $2500, but will also take reasonable offers. Feel free to ask questions if you would like more information.
Asus VT168H 15.6" 1366x768 HDMI VGA 10-Point Touch Eye Care Monitor, 15.6-inch
NB North Bayou Monitor Desk Mount Stand Full Motion Swivel Monitor Arm with Gas Spring for 17-30’'Monitors(Within 4.4lbs to 19.8lbs) Computer Monitor
Timberline 140-10 Carbide Tipped Keyhole 3/8 D x 3/8 CH x 1/4 Inch SHK Router Bit
Amana Tool 45525 Carbide Tipped 1-1/8 Dia x 1/2 CH x 1/4 Shk x 1-13/16 Long Spoilboard Surfacing & Flattening 3-Flute Router Bit
Amana Tool 45624-K SC Spektra Extreme Tool Life Coated V-Groove 60 Deg x 1/4 D x 7/32 CH x 1/4 Inch SHK 3-Flute Router Bit
Amana Tool 45626-K SC Spektra Extreme Tool Life Coated V-Groove 90 Deg x 1/4 D x 1/8 CH x 1/4 Inch SHK 3-Flute Router Bit
Amana Tool 45707 Carbide Tipped Zero Point V Groove 60 Deg x 1/2 D x 9/16 CH x 1/4 Inch SHK Router Bit
Amana Tool 45714 Carbide Tipped V Groove 90 Deg x 3/4 D x 5/8 CH x 1/4 Inch SHK Router Bit
Amana Tool 45773-K Solid Carbide Spektra Extreme Tool Life Coated 30 Degree Engraving 0.020 Tip Width x 1/4 SHK x 2-1/4 Inch Long Signmaking Router Bit
Amana Tool 45910 Carbide Tipped Core Box 1/4 R x 1/2 D x 3/8 CH x 1/4 Inch SHK Router Bit
Amana Tool 45918 Carbide Tipped Core Box 3/8 R x 3/4 D x 7/16 CH x 1/4 Inch SHK Router Bit
Amana Tool 45981 Carbide Tipped Bowl & Tray 1/8 R x 1/2 D x 1/2 CH x 1/4 Inch SHK Router Bit
Amana Tool 45982 Carbide Tipped Bowl & Tray 1/4 R x 3/4 D x 5/8 CH x 1/4 Inch SHK Router Bit
Amana Tool 46009-K SC Spektra Extreme Tool Life Coated Spiral Plunge 1/16 Dia x 1/2 CH x 1/4 SHK 2 Inch Long Up-Cut Router Bit
Amana Tool 46125-K SC Spektra Extreme Tool Life Coated Spiral Plunge 1/8 Dia x 13/16 CH x 1/4 SHK 2-1/2 Inch Long Up-Cut Router Bit
Amana Tool 46176-K CNC SC Spektra Extreme Tool Life Coated Compression Spiral 1/8 D x 13/16 CH x 1/4 SHK x 2-1/2 Inch Long Router Bit
Amana Tool 46225-K SC Spektra Extreme Tool Life Coated Spiral Plunge 1/8 Dia x 13/16 CH x 1/4 SHK 2-1/2 Inch Long Down-Cut Router Bit
Amana Tool 46282-K CNC Spektra Extreme Tool Life Coated SC 2D and 3D Carving 5.4 Deg Tapered Angle Ball Nose x 1/16 D x 1/32 R x 1 CH x 1/4 SHK x 3 Inch Long x 4 Flute Router Bit
Amana Tool 46286-K CNC Spektra Extreme Tool Life Coated SC 2D and 3D Carving 3.6 Deg Tapered Angle Ball Nose x 1/8 D x 1/16 R x 1 CH x 1/4 SHK x 3 Inch Long x 3 Flute Router Bit
Amana Tool 46350-K CNC SC Spektra Extreme Tool Life Coated Mortise Compression Spiral 1/4 D x 1 CH 1/4 SHK 2-1/2 Inch Long 2 Flute Router Bit
Amana Tool 46403-K SC Spektra Extreme Tool Life Coated Spiral Plunge 1/16 Dia x 1/2 CH x 1/4 SHK 2 Inch Long Down-Cut Router Bit
Amana Tool 46415-K SC Spektra Extreme Tool Life Coated Spiral Plunge 1/4 Dia x 1 CH x 1/4 SHK 2-1/2 Inch Long Down-Cut Router Bit
Amana Tool 46700-K CNC SC Spektra Extreme Tool Life Coated Compression Spiral 1/4 D x 7/8 CH x 1/4 SHK x 2-1/2 Inch Long 2 Flute Router Bit for Birch Plywood
