# Z-Axis error on first startup
**URL:** <https://forum.onefinitycnc.com/t/z-axis-error-on-first-startup/16074>\
**Created:** [October 25, 2022, 12:28pm UTC](https://forum.onefinitycnc.com/t/z-axis-error-on-first-startup/16074 "2022-10-25T12:28:09Z")\
**Author:** ![newbiee](https://sea2.discourse-cdn.com/flex022/user_avatar/forum.onefinitycnc.com/newbiee/32/8326_2.png) [@newbiee](https://forum.onefinitycnc.com/u/newbiee)\
**Post date:** [October 25, 2022, 1:41pm UTC](https://forum.onefinitycnc.com/t/z-axis-error-on-first-startup/16074/2 "2022-10-25T13:41:02Z")
Yes, this is normal. The home is found by an (i think) amperage spike threshold that is adjustable. [Here](https://forum.onefinitycnc.com/t/help-my-toolpath-says-under-or-over-with-videos/1982) is the over-under explanation. Essentially, it will go away when you load a file and zero your XYZ if your tool paths are correct.
_[View the full topic](https://forum.onefinitycnc.com/t/z-axis-error-on-first-startup/16074)._
