z axis works with a joystick and a button on the controller. First I set the home point XYZ. All this is ok, no errors. When I load the program axis z does not work for me, x and y work without problems. The program is executed to the end without axis z. even if I only make a test program with the aspire program (one carve and one hole), the z axis does not want to go down and make a hole or carve.
Uros, make certain that you are using the Onefinity post processor when you save your toolpaths in VCarve/Aspire.
Make sure you did not select the “Laser” post processor version. Laser engraving removes Z movement as it needs to retain a constant focus.
Yes i use laser before next job with cnc. Now i select Onefinity post processor and all is normal. Thanks @Alphonse and @Matticustard.
