Apprentice Redline Test file
Did you know that the Team Onefinity sign that came with your CNC was actually cut by your machine? That’s not just for style points. Every CNC we make is fully assembled, tested, and checked for quality before leaving our facility. The g-code that comes pre-loaded is what we use to make sure your machine is in tip top shape before it ships out. Pretty neat, huh?
That’s why we recommend repeating this test after you first set up your CNC. This is the easiest way to ensure that the machine was correctly assembled, and to get you familiar with how the machine works. You’ll load a program, position and secure your material, and learn the basic order of operations to be successful with your own designs. Not to mention, you end up with a pretty snazzy little sign for your shop!
GCODE Redline File:
Redline_Apprentice Test File.nc (15.4 KB)
Vectric:
Apprentice Test File VECTRIC.crv (166.5 KB)
Carveco:
Apprentice Test File CARVECO.art (1.2 MB)
Tool and Job Details
Tool Setter:
Disabled
ATC:
No
Job Type:
Single Sided
Job Height:
4.75 Inches
Job Width:
11 Inches
Job Thickness:
0.5 Inches
Job Settings
Z Zero Position:
Material Surface
XY Datum Position:
Lower Left
Software:
VectricCarveco
Material:
Wood (hard)
