Beginners logo inlay
Or do you simply mean you want a delineation at the “overlap”? If so, there are still no overlapping vectors. But the design would look something like this…
As for the size, 1" is tiny. You may have a difficult time at that size.
yup you got it. Thanks I have a steep learning curve ahead.
Got it! New file package:
BC LOGO CIRCLES DESIGNED 2.6.zip (248.8 KB)
You can see how the vectors have changed from the original. No overlaps! :rofl:
I see the two complete vectors now.
That one would be the mirror image and flipped over . Then i would need to manually add the lines for the tail of the B.
i used Carbide create to cut the inlay piece but i couldnt raise the Z to change bits from the 1/8 to the 60 vbit
I provided two design options in each of the SVG files (4 designs total). Pick whichever you like better and mirror it when carving the male/plug side of the inlay. The designs are ready to use.
You’ve lost me again… What are you adding lines for now? I thought we addressed that with the newest iteration.
Save separate tools as separate gcode files. Then you don’t have to worry about tool changes in the middle of a program.
Thanks for the help. Turned out ok.
