Elite Forman (Masso) started Throwing axis alarms when router kicks on
This all started when I needed to replace the brushes for my Makita router, the RT0701C. I bought cheap ones from Amazon, thinking that brushes were brushes.
Once I did that, I started having problems. The Z-axis motor would cut in and out on tool paths I have cut before, and I found that excessive vibration would cause the power cords to vibrate loose. Some weather stripping and electrical tape resolved the problem for a moment. Then I was doing a flattening path that I had done before. It was a G-code that was set as a single path. Would set the tool depth. Then readjusted my zero to the depth I want to cut, usually about 0.040 inches during the run. Halfway through, I got a Z-alarm, and the machine shut down. I cleared the code, thinking it was an error, jumped to a couple of lines before, and started again. It ran about another quarter way through the path and threw a code again. I shut the machine down. Oiled the ball and screws in case of binding. Cleaned everything up. Cleared the homing channels and checked for pinched wires. I fired everything back up and jumped to line about 2 lines before where it had cut out, and it threw an alarm about 30 seconds into carving. Wondering if I had lost some communication through wires, I checked continuity on all my Z-axis wires, and everything checked good, even wiggled and waved them around to make sure I had solid connections, and still had solid connections throughout. I swapped the Z and X stepper motors to see if the problem stayed at the Z-axis or moved with the motor. When I moved it to the X-axis, it moved with it, so it made me think that the problem was the motor. I contacted Onefiniity, and they believed it was the stepper motor going out as well. I ordered a new one.
When it arrived, I replaced the X-axis stepper motor with the new one. Keyed everything up, and as soon as the router kicks on, even manually, not just for a tool path, an alarm is triggered for X-axis alarm. When I moved the motors, I reloaded the tool settings and also upgraded the software to the latest v5.12
This led me to believe that the brushes I bought were not of proper quality and causing high interference and creating Electro Magnetic Interference. I purchased OEM brushes from Makita and replaced them, hoping that would resolve the problem. However, after replacing them, I still get the automatic X-axis alarm.
I am at a loss as to what the issue is now, if anyone has ideas. Is my whole router causing EMI? Why is my alarm now still on the X-axis with the new Masso stepper motor (did loading the tool setting just not take, and I need to load it again)? I am getting frustrated and getting gray hairs.
Run an air cut without the router turned on and see if you still get the errors. This will tell you if it is the router or the machine.
Sounds like the motor is grounding to the chassis
Check for any voltage between the spindle exterior and ground
What is the proper way to test for this?
Using a multimeter set for voltage
check for voltage between the spindle body and a common ground with the router plugged into an outlet but turn off
If no stray voltage is measured then test with router on
If still no voltage is detected then it’s not stray voltage in the router body
I will check both of these this evening, thank you for the responses. I will report back with my findings
Did a dry run with the router off and had no issues
this is voltage with no power going to the router.
This is voltage with power going to the router.
I currently have my router plugged into the back of the back of the control box. But I unplugged it and plugged it into a different power source and get the same problem.
So what does this mean?
So if you can run the cnc without the router in the machine with no problems then you probably need a new router. Sorry.
Well installed a new stepper motor ordered from onefinity and just got my Makita back from their warranty service and they rebuilt it and now my x axis is throwing an alarm and has intermittent power. So now troubleshooting again with onefinity for a solution…
Hi Bryan,
What was the final resolution on your problem? I am trying to troubleshoot something very similar.
Thanks, John
