Facing toolpath is very rough
I am using a Gen 2 Redline Foreman and getting a unique problem I never had with my X50 woodworker. I face with a 1/4” tool since ATC is not available yet, and I used to do the same with the X50.
Settings are scaled way back so feed is slow and speed is high. Tram is excellent, bolts are tight. Using the heavy QCW. Pushing and pulling on the spindle (redline) gives about 0.020” flex front to back and maybe 0.005” side to side. Reset acceleration to be very slow after initially making things very fast.
Toolpath was generated on fusion 360 using pocket toolpath, not facing because the shape is not that simple so I don’t want to waste time facing scrap.
Example image below. What else should I try? Again, this toolpath used to work, it would required sanding as the tram wasn’t as good and it would leave faint burns at the spots where it paused, but it was acceptable to just remove with a quick belt sanding. This is much deeper.
Are you on the lates 1.4.18 firmware?
Is your bit new?
Updated and brand new bit
Is the surface that you are machining flat?
Are you doing a final lighter finishing pass in the pocket, or is the pocket toolpath a roughing pass with relatively large stepdown?
I understand this won’t explain the discrepancy between machines.
yea it’s intended to be flat and it starts from a fairly flat piece. It’s maybe a 2mm step down which has typically worked, but some of the pieces on this board also have a .2mm finishing step down. I also ran (on a piece not pictured) this surfacing path twice, the second one with Z being 0.5mm lower. It is somewhat better but still way too rough for what it normally is.
This shouldn’t matter, but when I fixed the tram yesterday I used .010” shim stock behind the Z sliders bottom bolts. These bolts are tight but I wondered if there could be flexibility from introducing a subtle gap between the bearing block and Z slider mounting plate? Not enough to gouge like this though
Another note, My spindle is mounted with the clamp about half way down, maybe I can move the clamp closer to the collet end but I’ll have to remove, and retram the Z slider. I played with spindle mounting on previous machine and didn’t notice these kinds of effects.
What kind of 1/4 bit are you using? If its one of those straight fluted ones with the carbide brazed on I could see this happening because most of the time those dont have a flat face. The carbide cutting edges stick down further than the center of the bit creating a swirling pattern.
This is the same 1/4” spiral down cut carbide bit I always use. I think it’s SpeTool or something cheap but it’s the same bit I’ve been using for years with good results. Equally good to something like Bits and Bits, except longevity. The bit style hasn’t changed just the machine has.
Have you done many such projects on the new machine at this point, to rule out whether this was a one-off vs a consistent floor finish issue?
And the post processor right, it looks like it adds a dwell at the bottom for some reason.
Pat
Pat
I’ve run 3 or 4 of these so far to test and they all behave like this. I’ve probably made a hundred using this method on the first machine. Dropping feed to 10% reduces the effect but it’s still there. I will attempt a true facing tool path in one direction only and see if the direction change is giving me issues.
There’s no programmed dwell, it just changes direction at those points so it lingers a moment longer and any deflection might settle at that moment.
I found it a while ago and it may be of interest https://www.youtube.com/watch?v=BMBIws64lZM
I use Fusion, and mill mostly aluminum, so some of these toolpaths are either difficult to replicate of unavailable, but the concepts may be helpful.
Try cleaning the collet or using a different one. It’s possible you got a defective one with your new machine and getting bit slippage.
For what it’s worth, I had a Y-axis repeatability problem when I installed an Elite/Masso upgrade on my BB Foreman. After considerable frustration, I tracked the problem to the “factory-installed” shaft coupler on one of the new Y-axis motors. The set screw that clamps the coupler to the motor shaft wasn’t tightened well, and the coupler could slip on the shaft by a partial turn, but not a full one. After I tightened it properly, the repeatability problem was gone. So I’d suggest checking out all the Z-axis mechanical connections on your upgraded machine.
I appreciate the last 3 suggestions and will check them out on Monday when I’m back at the machine and follow up. I was able to get a better finish with a single direction facing toolpath on the x axis, but still rough. I will check all connections and I have just cleaned the collets. Thanks gang, happy Easter if you’re celebrating
@BuckeyeDennis All connections seem tight, was your issue more complex than just tight screws? I hoped it was that simple for me.
@TommyObar Collet is cleaned and no change.
@OnefinityCNC Any suggestions?
Just thinking out of the box here. Is it possible your new spoiler board is flexing (bending, not showing off :smiley:)?
I’ve considered it, and I don’t know how to rule it out. I’m using the heavy QCW and it is well secured to the table using the provided screws. I read some movement when pushing on the table with a deflection gauge mounted but nothing crazy. I am going to run again using the smarter path @TMToronto mentioned with a .5mm finishing stepdown.
In my case it really was a simple as loose clamp screws in the motor coupler. Simple to fix, that is, but a hassle to diagnose.
I just ran this tool path with no luck. It seems the direction change cuts deeper than .5mm. I could make the finishing step smaller but I think this will result in a continuously shrinking step down to remove this. I feel this somehow must be a hardware issue. I will reach out to @OnefinityCNC support and let everyone know what I find. Open to more suggestions here.
