First Cut: Elite Gen 2 Elite Foreman - VECTRIC Users! Learn your Onefinity CNC with Christy!
Aspire is not really a 3d modeling software, it’s more of a 3d relief software. Vcarve has all of the same CAM capabilities as Aspire (correct me if I’m wrong) but as far as CAD goes Aspire as the ability to import multiple 3d models and then edit them, blend them and combine them. Aspire is great for sign making, but I don’t do much of that, so I have been just fine with vcarve pro. The other nice thing is if you start off with Vcarve and decide to upgrade, you don’t lose anything. Vectric only charges the difference between the two.
Thanks, this will be my first experience with a CNC. I have worked with solid modelling tools several years ago. Just a couple of questions, what makes Aspire so great with signs? I have also purchased the 4th axis and someday I would like to start using it to make wood models of airplanes. Thoughts?
I would say watch some videos on Aspire. It’s very powerful for art based designs and relief carvings….You wouldn’t be able to create a 3d model of a plane only a relief of one. If you had a 3d model of a plane, you could import it into vcarve or aspire and use it to create a CAM file to turn on your 4th axis. If you are looking for hard core 3d modeling a lot of people use Fusion 360. I have tried using it but the learning curve is bigger than I have time for. I can do mostly everything I want in the few programs I have gotten familiar with over the years. Vcarve/Aspire are very easy and powerful enough for creating tool paths. It does not have super advanced machining strategies like trochoidal milling or adaptive milling, but most get along fine without them. I find I can usually bring in a design and have tool paths done in a few minutes on Vcarve…that it what I like and use it for…I have yet to figure out how to draw and design efficiently in it. I use a different program for that.
Out of curiosity what’s the other program(s) you use?
Thanks!
The main other program that I draw in is called MOI3D (Moment of Inspiration). https://moi3d.com/
I have been using it for a long time and I can usually do what I want pretty easily. I am definitely not a power user on any program. I also use it for making 3d printed parts. Generally for the things I want to do I can get from point A to point B pretty quickly. It’s part of the reason I haven’t conquered any other software. I just haven’t found anything that is as intuitive for me personally.
Garrett on IDC has a video on how you can do this in VCarve Pro. It’s not quite as robust as Aspire but will do the job for many folks
Mark lyndsey is also a great resource!
