After much back and forth at Apple my GCodeGen app is available for testing on iOS devices at Join the GCodeGen beta - TestFlight - Apple. The first ten to sign up and help me test will receive a free copy.
The app is initially setup for resurfacing jobs in which you can quickly define the stock size, bit size, cutting control for a job. You can generate gcode for different home positions and cutting patterns including uni-directional and circular patterns.
You can also use mixed units, define you stock and bits in inches but your cutting in millimeters.
View and edit the resulting GCode and even send it to the BuildBotics controller using SFTP or SMB (assumes you have SSH setup).
These are just the inital features with much more planned.
