HELP! WW Doesn't move in X direction while running GCode
Good Saturday Morning. Having a issue running GCode. Link to video, which may be better description than I can write. https://photos.app.goo.gl/KYVQzne4ee3TNgLE8
Also will post the actual GCode below.
The new WW worked great out of the box. Did some holes for my spoil board / table top along the y rails on the first day. Comeback to do the holes in the center, and after it does the first hole, it will no longer move in the X direction. However, I can move it using MDI commands.
Let me say, I was working with 1F support Friday, but we weren’t making much progress before they closed. What I am asking help on today is after hours of narrowing down the issue. Meaning, I have tested cables, oiled the machine, checked the couple between the motor and the rail. Moved all around the machine with controller/gamepad etc.
Here is the GCode.
T142 (MSG, Insert Tool 142)
G0 G17 G20 G90 G49
G0 Z0.9500
G0 X0.0000 Y0.0000 M03 S12000
M0(MSG, Click ‘Continue’ when the spindle is up to speed)
G0X0.9672Y1.0000Z0.9500
G1Z0.6500F25.0
G3X1.0000Y0.9672I0.0328J0.0000F250.0
G3X1.0328Y1.0000I0.0000J0.0328
G3X1.0000Y1.0328I-0.0328J0.0000
G3X0.9672Y1.0000I0.0000J-0.0328
G0Z0.9500
G1Z0.5500F25.0
G0Z0.9500
G0X2.0000Y0.9672
G1Z0.6500F25.0
G3X2.0327Y1.0000I0.0000J0.0328F250.0
G3X2.0000Y1.0328I-0.0327J0.0000
G3X1.9672Y1.0000I0.0000J-0.0328
G3X2.0000Y0.9672I0.0328J0.0000
G0Z0.9500
G1Z0.5500F25.0
G0Z0.9500
G0X3.0000
G1Z0.6500F25.0
G3X3.0327Y1.0000I0.0000J0.0328F250.0
G3X3.0000Y1.0328I-0.0327J0.0000
G3X2.9673Y1.0000I0.0000J-0.0328
G3X3.0000Y0.9672I0.0327J0.0000
G0Z0.9500
G1Z0.5500F25.0
G0Z0.9500
G0X5.0000
G1Z0.6500F25.0
G3X5.0328Y1.0000I0.0000J0.0328F250.0
G3X5.0000Y1.0328I-0.0328J0.0000
G3X4.9672Y1.0000I0.0000J-0.0328
G3X5.0000Y0.9672I0.0328J0.0000
G0Z0.9500
G1Z0.5500F25.0
G0Z0.9500
G0X7.0000
G1Z0.6500F25.0
G3X7.0328Y1.0000I0.0000J0.0328F250.0
G3X7.0000Y1.0328I-0.0328J0.0000
G3X6.9672Y1.0000I0.0000J-0.0328
G3X7.0000Y0.9672I0.0328J0.0000
G0Z0.9500
G1Z0.5500F25.0
G0Z0.9500
G0X9.0000
G1Z0.6500F25.0
G3X9.0328Y1.0000I0.0000J0.0328F250.0
G3X9.0000Y1.0328I-0.0328J0.0000
G3X8.9672Y1.0000I0.0000J-0.0328
G3X9.0000Y0.9672I0.0328J0.0000
G0Z0.9500
G1Z0.5500F25.0
G0Z0.9500
G0X12.0000
G1Z0.6500F25.0
G3X12.0328Y1.0000I0.0000J0.0328F250.0
G3X12.0000Y1.0328I-0.0328J0.0000
G3X11.9672Y1.0000I0.0000J-0.0328
G3X12.0000Y0.9672I0.0328J0.0000
G0Z0.9500
G1Z0.5500F25.0
G0Z0.9500
G0X15.0000
G1Z0.6500F25.0
G3X15.0328Y1.0000I0.0000J0.0328F250.0
G3X15.0000Y1.0328I-0.0328J0.0000
G3X14.9672Y1.0000I0.0000J-0.0328
G3X15.0000Y0.9672I0.0328J0.0000
G0Z0.9500
G1Z0.5500F25.0
G0Z0.9500
G0X18.0000
G1Z0.6500F25.0
G3X18.0327Y1.0000I0.0000J0.0328F250.0
G3X18.0000Y1.0328I-0.0327J0.0000
G3X17.9673Y1.0000I0.0000J-0.0328
G3X18.0000Y0.9672I0.0327J0.0000
G0Z0.9500
G1Z0.5500F25.0
G0Z0.9500
G0X21.0000
G1Z0.6500F25.0
G3X21.0327Y1.0000I0.0000J0.0328F250.0
G3X21.0000Y1.0328I-0.0327J0.0000
G3X20.9673Y1.0000I0.0000J-0.0328
G3X21.0000Y0.9672I0.0327J0.0000
G0Z0.9500
G1Z0.5500F25.0
G0Z0.9500
G0X24.0000
G1Z0.6500F25.0
G3X24.0327Y1.0000I0.0000J0.0328F250.0
G3X24.0000Y1.0328I-0.0327J0.0000
G3X23.9673Y1.0000I0.0000J-0.0328
G3X24.0000Y0.9672I0.0327J0.0000
G0Z0.9500
G1Z0.5500F25.0
G0Z0.9500
G0X30.0000
G1Z0.6500F25.0
G3X30.0327Y1.0000I0.0000J0.0328F250.0
G3X30.0000Y1.0328I-0.0327J0.0000
G3X29.9673Y1.0000I0.0000J-0.0328
G3X30.0000Y0.9672I0.0327J0.0000
G0Z0.9500
G1Z0.5500F25.0
G0Z0.9500
M5
G0 Z0.9500
G0 X0.0000 Y0.0000
M2
It looks like you need to update your 1F. Try updating to the new version and see if the problem continues. Also make sure you are using the correct and most updated post processor in your cam software.
I reinstalled the post processor, no change. I upgraded to 1.0.8 had same issue, rolled back to 1.0.7. Same issue, I am in the process of flashing the SD card so that its like factory fresh. We’ll see what that does.
Which processor are you using? It looks like the wrong code
Here is a sample of what my gcode looks like %
T1 (MSG, Insert Tool 1)
G0 G17 G20 G90 G40 G49 G64
G0 Z1.779
G0 X0.000 Y0.000 M03 S12000
G0 X-0.000 Y-0.002 Z0.050
G1 F50.0
G1 X4.000 Y-0.002 Z0.025
G1 X-0.000 Y-0.002 Z-0.001
G1 X16.000 Y-0.002 F100.0
Y0.392
X-0.000 Y0.392
Y0.787
X16.000 Y0.787
Y1.181
X-0.000 Y1.181
Y1.575
X16.000 Y1.575
Y1.969
X-0.000 Y1.969
Y2.364
X16.000 Y2.364
Y2.758
X-0.000 Y2.758
Y3.152
X16.000 Y3.152
Y3.546
X-0.000 Y3.546
Y3.940
X16.000 Y3.940
Y4.335
Also what software are you using?
Problem seems to be fixed now. I had to reload the operating system by flashing the SD Card. Just finish cutting all the holes in the table top.
Vectric Aspire. OneFinity Inch Post Processor.
