Just purchased Elite Foreman, what prep can I do?
It’s a really good idea. So good, in fact, that I’m definitely going to be using it myself :grin: . I happen to have loads of scrap 8020 from my work facility that I rescue out of the scrap metal recycling bin.
Well. Don’t just stand there; write a book! Or at least a blog. I, a twenty year veteran of the CNC invasion, need all the education I can get.
All custom, You buy the 2020 or 8020 Metal and cut then add plastic.
@mhackney Thank you so much for your inputs, greatly appreciate them as a newbie, it makes a lot of sense!! Greetings from Spain
Power, lighting, and table,… I recommend 2-3 120V duplex outlets and a 240V outlet in the immediate area of your CNC, if you do a standard setup with your CNC, placing them a few inches left of the left-rear of the table will put them closest to where all the power is needed.
For lighting, have a plan to illuminate your work area fairly well (you’ll want to see details in your work).
Finally the table, keep future upgrades/add-ons in mind when designing/building it. I wish I’d built mine 6 inches wider as I already have components hanging over the edge due to upgrades/add-ons.
Many have upgraded to a larger drag chain as the one provided by 1F is quite the joke once you add spindle coolant lines, laser cables and air, etc, etc…
Is the Nighthawk compatible with the ATC? Thanks.
