Need a solution very badly
Journeyman X-50: Indexed Pocket B Misalignment Despite Mirrored G-Code
I’m troubleshooting two long pocket toolpaths for a 57-inch mission-style backrest on a Onefinity Journeyman X-50 using the Buildbotics controller, firmware v1.6.6, and VCarve Pro 11.554.
Because the board is longer than the machine bed, the process is:
  1. Run Pocket A.
  2. Rotate the board 180° end-for-end.
  3. Reposition it against fixed indexing blocks.
  4. Run Pocket B so it joins Pocket A.
Setup completed:
  • Spoilboard edges were machined square using the CNC.
  • Fence was reinstalled against the newly squared spoilboard.
  • A rear stop maintains a 1-inch offset.
  • Two identical 7-5/16-inch fixture blocks locate the board.
  • The board is exactly 3.500 inches wide.
  • X/Y were reprobed from the newly machined spoilboard corner.
  • Z was probed from the top of the workpiece.
  • Pocket A cuts correctly.
  • The material is rotated 180° and seated firmly against the same fixtures before Pocket B.
Problem:
Pocket B begins correctly in the middle of the intended pocket. Its center clearing pass runs correctly. The next clearing pass also appears to line up with Pocket A.
After clearing toward X0, however, the tool reaches the end of the vector, crosses to the opposite side, and cuts the final outside wall farther away from Pocket A. This creates a visible step at the A-to-B transition.
The movement is repeatable and occurs at the same location.
G-code comparison:
Pocket A final cutter-center boundaries:
  • X = 8.000
  • X = 8.740
  • Center = 8.370
Pocket B V3 final cutter-center boundaries:
  • X = 9.510
  • X = 10.250
  • Center = 9.880
The files appear to be exact mirrors around X = 9.125:
  • 8.000 mirrors to 10.250
  • 8.740 mirrors to 9.510
  • 8.370 mirrors to 9.880
Pocket B V3 contains only one toolpath. There is no duplicate or older toolpath appended. Its programmed final perimeter includes:
G1 X9.5100 Y0.5186
G1 X10.2500
G1 Y30.7686
The machine is therefore following the uploaded G-code, but the physical Pocket B wall is not matching Pocket A after the board is rotated.
I am currently verifying that the physical centerline of the 3.500-inch board lands at X = 9.125 when seated in the fixture.
Has anyone encountered this on a Journeyman X-50 indexed setup? Specifically:
  • Is there another fixture or work-offset measurement I should verify?
  • Could the Buildbotics work offset be affecting the mirrored position after probing?
  • Is there a recommended method for verifying the exact rotational center of indexed material?
  • Is there anything in these A/B coordinates that I am overlooking?
I’m trying to determine whether this is still a fixture-position issue, a work-coordinate issue, or something mechanical in the machine.
Not a criticism but why didn’t you just tile the pocket?
You can keep the piece against a fence that is known parallel to one axis.
Typically for me if there is an error its my setup not the software.
That being said when I’m mirroring parts my job setup starts at the center of the piece.
Just a couple of thoughts.
Is the Onefinity actually square? Many posts on here ref checking a square machine.
I would fix a temp fence/fences to the spoil board and machine them after zeroing the machine before going stright into machining the pockets. This would mean you dont have to probe as you with have your zero’s from the fresh milled fences.
I would suggest the error is occurring when you rotate the work piece through 180 degrees, could you not just slide the work piece along one of the fences?
I do a lot of pocket / area clearance jobs and I always complete the clearance but leaving 0.25mm on the sides of the pocket to allow me to run an internal profile path at full size but just reduce the depth of the profile path by about .05mm so the cutter doesn’t mark the floor of the pocket.
Going back to apprentice school circa 1984 we were taught its ok to slide a workpiece but not to rotate.
Hope this may help
D
That Is essentially what I need to learn, I do not have the machine oriented to do that, HOWEVER, you just reminded me to make this a priority, Thank you.
Thank you for the input, yes the machine is square I have had it set up for a bout 4 years and I feel very confident that step was done perfectly, I have since confirmed the Y Axis was net exactly square so I just ran a new spoil-board file and squared up the board and added my fences back on, it looks amazing now.
I have neve done a tiling project and to be honest my machine orientation was never placed with the understanding of that type of operation, that idea has been reignited and I need to bo a ton of research on tiling, This would save me an incredible amount of time, any tutorials ARE appreciated!
