Does anyone know how to select a specific G code line so as to skip ahead or return to a previous line?
You cannot do that, you have to delete all the previous lines (minus header) if you want to pick up where you left off. This clearly requires you to know which line you stopped at as well. There are several discussions on the forum regarding this if you search.
Overall, OF does not control the GCode once its imported you have to do that in the file side then re-import.
Hope that helps,
-Alex
Thanks, that’s what I needed to know.
