3D Relief + Laser Shading = PURE MAGIC!
In this video, Morgan shows you how to add shading to your 3D relief using the Onefinity CNC and @JTechPhotonics laser, and you won’t believe the results. If you’re looking to take your 3D carves to the next level, follow along for great setup tips, tooling, and beginner-friendly CNC advice. This walkthrough will help you create a work of art you never thought possible! Many CNC users find themselves limited to clipart or purchased cut files - those days are over. This new technique is surprisingly easy and will take your CNC projects to the next level.
This video will cover:
• Generating a one-of-a-kind model with Ai that you can cut TODAY
• Best practices for toolpathing a 3D relief
• Carveco’s image-to-relief tool
• Lightburn for laser shading
• Getting to know Bigfoot, the original “Florida Man”
Download the FREE cut/burn files and use them as a guide to create your own masterpiece!
Bigfoot Florida Man.zip (16.6 MB)
:small_blue_diamond: PRODUCTS & TOOLS USED IN THIS VIDEO
:hammer_and_wrench: Machine: Onefinity CNC Elite Foreman with Redline CNC controller– https://www.onefinitycnc.com/product-page/gen2eliteseries
:cyclone: Bits & Tooling: -
The “Jenny” 1/4" compression spiral bit – https://www.onefinitycnc.com/product-page/the-jenny-bit-double-pack
Bits & Bits 1/8", 7-degree tapered ball nose - https://bitsbits.com/product/4teb7-125-3fl/
Jtech Photonics 64w 3-in-1 laser (shown in 24w mode) - https://www.onefinitycnc.com/product-page/jtech-laser
:brain: Design Software:
Carveco Maker
Lightburn
:wood: Materials: - Wood: walnut, hard maple (any hardwood will do)
AI is theft. Support real artists :fu:
i don’t have a jtech but i do have a thunder, and i could totally see doing this to customer supplied artwork, great video! alignment wouldn’t even be an issue between the two machines.
Would be curious if you could share your ChatGPT prompts
Hey Morgan -
I live in Florida…matter of fact, I think that’s my face on your project!! Perfect!
That’s a great piece you did. Thanks for sharing.
Thank you! glad you like it!
This is fantastic! Question though, as a new gen2 user, could you provide some details around setting up light burn and or Vcarve Pro with the new redline controller? Any guidance there is greatly appreciated!
It’s similar to the gen1.
In the redline spindle/tool screen, you’ll choose pwm laser instead of redline spindle. Then just run your lightburn gcode file!
I guess that’s more where the problem lies. I get the gcode file but it won’t run :slight_smile: was just curious if there was anything special about setting up lightburn to generate code that the redline could read. I have changed the file to .nc and have updated the lightburn settings that are mentioned in the doc but calls out the Masso controller. I have created a basic test laser file in Vcarve and it works just fine but the gcode from light burn isn’t playing nice.
When setting up the machine for redline in lightburn, select grbl -m3 lightburn setup option
