Are Redline G-code compatible for Gen 1 Masso?
So I was looking on the filefinity forum and saw a file I would like to use but it was only listed for the Redline Post Processor.
It’s still an NC file so is it as simple as changing the post processor Information in NotePad or is there more to it?
No, they gcode is specifically for one or the other and are generally not compatible with different controllers.
I’m really struggling to believe this. Unless Redline is using some specialty codes, why would the gcode not work? I mean, it has been a standard since 1963.
Masso supports a metric sh*t ton more codes than Redline does - I haven’t done a detailed crosswalk but I don’t see anything that Redline supports that Masso does not.
and because I could, I asked the AI:
does gcode created for a redline controls work on a Masso controller? are all gcode commands supported by redline supported by Masso?
Yes, standard G-code files generated for a Redline CNC Controller will generally run on a MASSO controller, and MASSO supports virtually all standard commands used by Redline
. [1, 2]
Because Redline uses a much smaller, streamlined G-code dialect (~14 core G-codes outside of work coordinate systems) compared to MASSO’s broader industrial set (40+ G-codes), moving files from Redline to MASSO is far easier than moving in the opposite direction. [1]
G-Code & M-Code Compatibility Comparison
Command Group Redline CNC (RealTime CNC) MASSO Controller Compatibility Notes
Basic Motion (G0, G1, G2, G3) Supported Supported Identical standard behavior for rapids, lines, and arcs.
Units & Planes (G17–G21) Supported Supported Standard inch/mm and plane selection work identically.
Work Offsets (G54–G59) Basic support Extended support MASSO supports standard G54–G59 plus extended G54.1 offsets.
Dwell (G4) Supported (added in updates) Supported MASSO expects dwell time in milliseconds (P) or seconds depending on format—verify P parameter syntax.
Spindle & Coolant (M3, M5, M7–M9) Supported Supported Standard spindle on/off and accessory/mist/flood outputs (M7, M8, M9) match across both.
Tool Changes (M6 / T#) Supported Supported Both trigger tool change routines, though physical toolsetter coordinates and ATC logic are handled internally by each controller.
Practical Things to Check Before Running
  • Controller-Specific Headers/Footers: While the cutting moves will run cleanly, post-processors often insert setup lines at the start or end of a file (such as safe Z retracts using G28 or G53, or specific comment syntax). Review the first and last 10 lines of the .nc / .gcode file to ensure safe parking positions match your MASSO machine setup.
  • Tool Length Offsets (G43): Opinions are mixed on r/hobbycnc regarding Redline’s early firmware limitations, noting that G43 tool length offset support was prioritized later in development. MASSO supports G43 natively—just ensure your MASSO tool table is populated if the file calls G43 H#. [1]
  • Best Practice: Whenever possible, re-post the toolpath from your CAM software using an official MASSO post-processor so tool changes, arc tolerances, and safe retracts are tailored specifically to MASSO’s syntax.
If you share the CAM software you’re using or paste the first 15 lines of your G-code file, I can check it for any header or tool-change syntax differences.
Yeah I was skeptical too.
So I took the Redline file and asked ChatGPT to convert the roughing pass file for the Masso controller.
I ran an air carve this morning of the file and it seemed fine.
I’ll take some foam tomorrow and see if it will carve properly before committing to something more expensive
There is a reason that post processors for each machine exist. They inject code specific for each machine. Since they are similar, it will most likely work, but it many not work correctly.
