In Aspire, which post processor do you use for the Masso G3 Touch?
You use Masso ARCS mm or inch. If it isn’t on there you can download post processors. I had to as my version of aspire was 9.5.
There is also some altered ones as the one from Masso/ vectric doesnt have the command needed to turn on the attached vacuum
They updated it this week to include the m8 command to turn in the vac. If your on v11, refresh the machine configuration and it will download the updated onefinity eltite pp with the vac command on!
