Bit change on rotary
Just want to clarify a bit change when working with the rotary. after a roughing or rounding toolpath will the onefinity use the tool setter to sense tool height or do you need to set the “Z” height on the rotary block? Thanks in advance
good question I would like more info on the setting a job up and actual use with the rotary. not much available on you tube yet.
Yes it does use the tool setter for tool changes.
