Carbide Create Pro Post Processor for Onefinity (M6 Tool Change)
Folks, I don’t know if anyone has written this down before; if they have, I can’t find it, or what I did find was way complicated.
I did use AI to help me write the JavaScript. I had two developer friends review the code, and they said it was safe and good enough for our level of work. I am not a developer, I am a Network Architect and aspiring wood butcher. I hope this post helps someone. The code has made my workflow so much easier and the machine more enjoyable to use.
I am speaking and working from what I have learned using my machine for the last 3 years. I am by no means an expert or know everything about the device, but I do know I am making better workpieces each time I run the machine.
The Problem
Carbide Create’s built-in GRBL post processor outputs M0 ;T102 for tool changes. This is just a pause - it doesn’t trigger Onefinity’s tool-change macro.
The Onefinity controller only runs the code in the tool-change field when it sees an M6 command.
The Solution
A custom post-processor that outputs M6 T102 instead of M0 ;T102, plus a simple tool-change macro.
What Changes in the G-Code
Before (GRBL post-processor):
M05
M0 ;T102
M03S18000
After (Onefinity post-processor):
M05
(Move to safe Z to avoid workholding)
G53G0Z-5.000
(TOOL/MILL,3.17, 0.00, 0.00, 0.00)
M6T102
M03S18000
The key differences:
  • M6T102 replaces M0 ;T102 - This triggers the tool-change macro
  • Adds a safe Z move before tool change using machine coordinates
  • Adds tool dimension comments for visualization software
Requirements
  • Carbide Create Pro (subscription or perpetual license)
  • Onefinity with Buildbotics controller (firmware 1.4.0+)
Installing the Post Processor
  1. Download onefinity.post (link to your file)
  2. Open Carbide Create Pro
  3. Go to About → Open Data Directory
  4. Open the Posts folder
  5. Copy onefinity.post into the Posts folder
  6. Restart Carbide Create Pro
  7. Go to Edit → Select Post Processor
  8. Select “Onefinity (M6 Tool Change)”
Tool Change Macro
On your Onefinity controller:
  1. Tap the hamburger menu (☰) → Settings
  2. Scroll to the GCODE section
  3. Find the tool-change field
  4. Paste this code:
(Runs on M6, tool change)
M5
G4 P2
G53 G0 Z-1
M0 (MSG, Change Tool - Press Continue when ready)
  1. Tap Save
What this does:
  • M5 - Stops the spindle
  • G4 P2 - Waits 2 seconds for the spindle to stop
  • G53 G0 Z-1 - Moves Z to 1mm from the machine top (maximum clearance)
  • M0 - Pauses and displays a message to change the tool
After you press Continue, the G-code takes over - it starts the spindle and moves to the first cut position.
The Post-Processor Code
javascript
description = "Onefinity (M6 Tool Change)"
notes = "Onefinity Buildbotics controller with M6 tool changes for proper tool change macro support"
vendor = "Onefinity"
vendorUrl = "https://www.onefinitycnc.com"
outputMetric = true
extension = "nc"
function createFormatter(name, numDigits, useUnits) {
    var lastOutput = ""
    return {
        format: function(val) {
            if(val == undefined) {
                this.reset();
                return "";
            if(!outputMetric && useUnits) {
                val = val / 25.4
            var fmt = val.toFixed(numDigits);
            var ret = ""
            if(fmt != lastOutput) {
                ret += name;
                ret += fmt;
                lastOutput = fmt;
            return ret;
        reset: function() {
            lastOutput = "--"
function formatUnits(val) {
    var un = "mm"
    var digits = 2;
    if(!outputMetric) {
        val /= 25.4;
        un = "in"
        digits += 1;
    return "" + val.toFixed(digits) + un
function formatDimension(val) {
    var digits = 2;
    if(!outputMetric) {
        val /= 25.4;
        digits += 1;
function outputSafeZ() {
    if(state.wasHomeZ) {
        return
    var distFromTop = -5
    if(!outputMetric) {
        distFromTop /= 25.4
    onComment("Move to safe Z to avoid workholding")
    writeLn("G53G0Z"+distFromTop.toFixed(3))
    state.motionMode.reset()
    state.zval.reset()
    state.wasHomeZ = true
function writeBlock(){
    var ln = ""
    for (var i = 0; i < arguments.length; i++) {
        ln += arguments[i];
    writeLn(ln);
var state = {}
function onOpen() {
    var coordDigits = outputMetric?3:4
    state.xval = createFormatter("X", coordDigits, true)
    state.yval = createFormatter("Y", coordDigits, true)
    state.zval = createFormatter("Z", coordDigits, true)
    state.fval = createFormatter("F", 1, true)
    state.sval = createFormatter("S", 0)
    state.tval = createFormatter("T", 0)
    state.motionMode = createFormatter("G", 0)
    state.rpm = 0
    state.wasHomeZ = false
    state.lastTool = -1
    state.spindle = false
    onComment("Design File: " + sourceFilename);
    onComment("stockMin:"+formatUnits(stockMinX) + ", " + formatUnits(stockMinY) + ", " + formatUnits(stockMinZ))
    onComment("stockMax:"+formatUnits(stockMaxX) + ", " + formatUnits(stockMaxY) + ", " + formatUnits(stockMaxZ))
    var length = stockMaxX - stockMinX;
    var width = stockMaxY - stockMinY;
    var height = stockMaxZ - stockMinZ;
    onComment("STOCK/BLOCK,"+formatDimension(length) + ", " + formatDimension(width) + ", " + formatDimension(height) + "," + formatDimension(-stockMinX) + ", " + formatDimension(-stockMinY) + ", " + formatDimension(-stockMinZ))
    writeLn("G90")
    if(outputMetric) {
        writeLn("G21")
    } else {
        writeLn("G20")
    outputSafeZ();
function onClose() {
    if(state.spindle) {
        writeLn("M05");
    writeLn("M02");
function onTerminate() {
function onComment(text) {
    writeLn("(" + text + ")");
function onLinear(x, y, z, feed) {
        writeBlock(state.motionMode.format(1), state.xval.format(x), state.yval.format(y), state.fval.format(feed));
    var xv = state.xval.format(x);
    var yv = state.yval.format(y);
    var zv = state.zval.format(z);
    if(xv != "" || yv != "" || zv != "") {
        writeBlock(state.motionMode.format(1), xv, yv, zv, state.fval.format(feed));
function onRapid(x, y, z) {
        writeBlock(state.motionMode.format(0), state.xval.format(x), state.yval.format(y));
    writeBlock(state.motionMode.format(0), state.xval.format(x), state.yval.format(y), state.zval.format(z));
function onSpindleSpeed(s) {
    if(s <= 0) {
        writeBlock("M05")
    } else {
        state.spindle = true
        state.sval.reset()
        writeBlock("M03", state.sval.format(s))
    state.rpm = s
function onSection() {
    var tnum = toolNumber
    var force = forceToolChange
    if(tnum != state.lastTool || force == true) {
        state.lastTool = tnum
        onSpindleSpeed(0)
        outputSafeZ()
        onComment("TOOL/MILL,"+formatDimension(toolDiameter) + ", "+ formatDimension(toolCornerRadius) + ", " + formatDimension(toolFluteLength) + ", " + Number(toolAngle).toFixed(2))
        state.tval.reset()
        writeBlock("M6", state.tval.format(tnum));
        state.xval.reset()
        state.yval.reset()
        state.zval.reset()
        state.fval.reset()
Notes
  • I use collared bits, so all tools are the same length - no re-probing needed after tool change
  • Output is always metric (G21)
  • Tested with 1/8" and 1/4" endmills, 10° to 90° vee bits, and engraving
I like this ALOT! I’m using Aiph5u’s tool change routine currently to accomplish the same goal, however I still have to edit the GCode to insert the ‘M06’ command. Automating that from the post processor like you’ve lain out here is exciting!
I have a question though. I don’t know what I’m supposed to do with your script you’ve made. Do I copy it over to a text document, and just place that in the ‘posts’ folder of Create, or am I supposed to download something for that? I’m not the most educated on this topic! lol
Just for reference, the “Aiph5u’s tool change routine” I’m referring to is this: Aiph5u’s tool change - OneFinity forums
