So prior to the Carveco maker update i have been cranking out projects. I can not carve anything now. Z over error in 1" materials. Same things I have been making. I noticed there are now options for onefinity when saving. I have not been getting any to work. Other than finally dumping Carveco what can I do? Thanks!
I use Maker+ and haven’t had this. Which update are you talking about? Version/release date?
I think Onefinity CNC has been supported for a long time. I only started back in March but it was supported then. I use the inch no tool change one.
When you say “Z over error” what is it trying to do? I.e. What does it tell you the overage amount is? You have about 5" available. So long as you homed your Z correctly and have told Carveco maker to use the same location it should be fine.
Thank you everyone for trying to help troubleshoot. It turns out I needed to raise my Z Slider ![]()
