Lots of neat things from everyone.
Here’s a freebie for all of you. It’s a doorstop you can make out of scrap. I used 3/4" stock and a 1/8" compression bit for mine. You can change the depth of the recess to allow for your stock thickness,
VCarve, dxf, pdf are in the zip file.
Pony
Door Stop.zip (263.9 KB)
Very cool. Do you use something on the back foot to prevent the door from moving the door stop? Something like a piece of rubber?
Thanks,
I place a rubber pad under the feet. They have the thickness of a thin felt pad. Works good.
Pony
