I have read numerous posts regarding grounding / earthing of the CNC. I have some questions based on those posts I have read.
I have a 220V PwnCNC water cooled 80mm spindle and VFD. I have clipped a multimeter negative probe to the ground pin on the 220V plug coming off the VFD (which would be plugged into a dedicated 220V outlet). If I then touch the positive probe the the spindle I have continuity with less than 2 ohms. If I touch the positive probe to the Y and B rails, or the X rail I get between 6 and 10 ohms depending on what I probe. That resistance is not low enough from what I have read.
I am considering running some tinned copper braid from my spindle to my dust collection hose to groung the dust hose running to my dust boot.
I also want to install a grounding bus bar under my wooden CNC base/table to then run grounds to the CNC frame and/or the CNC control box and dust collector motor. The bus bar would then run to the ground which is plugged into a ground only dedicated 110V outlet. I should note that I have clipped my multimeter negative probe to the CNC control box 110V ground terminal on the plug. When probing with the positive probe i have no continuity to the Y, B or X rails.
Now my questions…
I understand STAR grounding which is why I want to install the ground bus bar. However, my spindle (and my dust collection hose if I ground to spindle) are grounded thru the VFD and 220V outlet. If I then ground the machine rails, the CNC control box and dust collector motor through a ground bus bar that then runs to a dedicated 110V outlet ground am I not creating a ground loop? How do I resolve this?
Also, regarding grounding to the rails, where on the machine specifically are you guys and gals connecting your ground wiring?
I’d appreciate your thoughts…
