NEW in v5.10
Download here: https://myworkshop.masso.com.au/
- RapidChange ATC Support - Added logic to support the Rapid Changer automatic tool changer. Setup Instructions
- French Keyboard Support - Full support added for the French keyboard layout, enhancing usability for international users.
Improvements & Bug fixes
- Probing Safety Logic - Added a warning message: “CAUTION: Touch probe not loaded in spindle!” when a probing cycle is initiated without the probe tool loaded.
- Job Time Tracking - Now displays elapsed and estimated job time on screen to improve job monitoring.
- Lathe Facing Wizard Fix - Resolved an issue in the Lathe Facing Wizard that caused incorrect toolpath generation.
- Probing File Logic Fix - Removed outdated logic that continued saving probing data to
MASSO Probe data.txt
. - G-Code Editor Fixes - Fixed multiple bugs in the G-code editor, including saving and file interaction issues.
- Macro Keyboard Fix - Resolved a bug that prevented the macro keyboard from working correctly.
- LCD Display - Fixed a graphical issue where a stray vertical line appeared on the right side in vertical screen layout.
- Spindle Control Enhancements
- Fixed delays and logic inconsistencies in spindle spin-up/down and direction changes.
- Corrected acceleration handling in PWM and STEP modes, previously only working properly in VFD mode.
- Fixed ACC/DCC issues for PWM and STEP spindle control.
- Tool Offset Logic in Multi-Head Systems - Fixed a bug where “Tool Dia Wear” values were incorrectly applied to B-axis offsets.
- Plasma System Improvements
- Improved torch hit detection during homing: if the torch is hit and axes are slaved, the slaved axis is now also stopped.
- Fixed ARC OK signal handling in the MASSO DTHC module when using
G200 S1
- MPG Override Fix - Fixed an issue where the spindle and feed override controls on screen were non-responsive during motion.
- Dry Run Coolant Indicator Fix - Resolved a visual issue where the coolant ON/OFF button did not update color status properly in dry run mode.
- Linear Tool Changer (Type 2) Fix - Fixed duplicate execution of spindle STOP logic during tool changes.
- Linear Tool Changer Tool Slot Initialization Fix - Fixed issue to ensure tool numbers are unrestricted, even if the number of tool slots is limited, providing better flexibility for setups with manually assigned tool numbers.
