after upgrading firmware on woodworker 35 software does not read tap files
What is a tap file?
If it contains regular gcode, then just rename the file extension from .tap to .nc
i use vectrtic software vcarve pro and it creates tap files and it has worked for a year until i upgraded firmware on woodworker 35 cnc
You’re not using the correct post processor for vectric. Use the Onefinity one. .tap ability has been removed.
