I purchased a .text file in etsy and converted it to .nc but when I run the program it is wanting to perform a touch probe procedure whic i dont have. Can and how do i delete this? Happy Thanksgiving Day
You need to open the nc file in an editor and delete the lines that call the probe. What lines to delete would depend on what post produced the file so I can’t tell you without seeing it.
If you can post the file I can have a look.
( H-1-inch )
( File created: Saturday, January 09, 2021 - 10:32 AM)
( for Mach2/3 from Vectric )
( Material Size)
( X= 8.000, Y= 8.000, Z= 0.750)
(Toolpaths used in this file:)
(V-Carve 2)
(Tools used in this file: )
(1 = V-Bit {90 deg 0.75"})
N100G00G20G17G90G40G49G80
N110G70G91.1
N120T1M06
N130 (V-Bit {90 deg 0.75"})
N140G00G43Z1.0000H1
N150S16000M03
N160(Toolpath:- V-Carve 2)
N170()
N180G94
N190X0.0000Y0.0000F60.0
N200G00X0.6250Y-0.0062Z0.2362
N210G1Z-0.0752F30.0
N220G1X0.6200Y0.0028Z-0.0719F60.0
N230G1X0.6143Y0.0149Z-0.0685
N240G1X0.6113Y0.0230Z-0.0669
N250G1X0.6062Y0.0443Z-0.0653
N260G1X0.6043Y0.0569Z-0.0667
N270G1X0.6034Y0.0625Z-0.0681
N280G1X0.6111Y0.0773Z-0.0625
N290G1X0.6347Y0.1278Z-0.0393
N300G1X0.6406Y0.1381Z-0.0349
N310G1X0.6441Y0.1429Z-0.0334
N320G1X0.6541Y0.1528Z-0.0319
N330G1X0.6639Y0.1593Z-0.0330
N340G1X0.6763Y0.1664Z-0.0357
N350G1X0.6889Y0.1761Z-0.0367
N360G1X0.7075Y0.1923Z-0.0376
N370G1X0.7236Y0.2052Z-0.0401
N380G1X0.7321Y0.2109Z-0.0425
N390G1X0.7442Y0.2046Z-0.0345
N400G1X0.7528Y0.1986Z-0.0298
N410G1X0.7566Y0.1953Z-0.0280
N420G1X0.7555Y0.1804Z-0.0149
N430G1X0.7550Y0.1718Z-0.0100
N440G1X0.7548Y0.1642Z-0.0096
N450G1X0.7519Y0.1453Z-0.0120
N460G1X0.7426Y0.1030Z-0.0204
N470G1X0.7405Y0.0960Z-0.0224
N480G1X0.7324Y0.0761Z-0.0300
N490G1X0.6991Y0.0275Z-0.0384
N500G1X0.6920Y0.0187Z-0.0408
N510G1X0.6867Y0.0134Z-0.0432
N520G1X0.6778Y0.0061Z-0.0479
N530G1X0.6610Y-0.0004Z-0.0548
N540G1X0.6477Y-0.0036Z-0.0616
N550G1X0.6250Y-0.0062Z-0.0752
N560G00Z0.2362
N570G1Z-0.0752F30.0
Not sure how much you will need so tell meif thats not enough
Mach 3 tap gcode files if that helps
Delete M06 on line N120.
If this file has more than one tool - it may have more M06 calls.
